![]() | Home > Puma (Tdci) > A Slight Problem for me, A big problem for LR. |
John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5014 ![]() ![]() |
d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044 ![]() ![]() ![]() |
I've got that cracking all along the front seam on my 22 yr old 90 and it doesn't leak water in (not from there anyway
![]() It's fine when I park it pointing downhill, so in the mean time I know what to do. DJ |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4754 ![]() ![]() |
Good luck with that! Our series 111 has no headlining and I still cannot find out where the water gets in! It lies in the internal gutter till you hit a corner or a slope then makes itself known.
![]() 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
elz Member Since: 23 Nov 2009 Location: Weybridge,Surrey Posts: 23 ![]() ![]() |
All sorted. Dealer took vehicle back, so what to buy next.
Sticky Member Since: 07 Dec 2008 Location: Derbyshire Posts: 245 ![]() ![]() ![]() |
Elz - I have had the same thing on my roof although I use a full length roof rack and I assumed that as I tightened the rack up it pulled the rails up into straight (mine were all over the place).
I got mine repaired and just expect this sort of issue. I suspect that you might always be disappointed with a Defender until the new one comes out. You will always find something you hadn't spotted before. |
Estate agents call that "charm" ![]() But shout it at them in German because life is also terrifying and confusing... |
