Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
fst_drvr Member Since: 08 Apr 2024 Location: Los Angeles, CA Posts: 5 |
I see... No wonder it didn't work on my car, I have a US spec 2022 p400, well guess I'll do it manually. BTW what do you mean by lithium battery? I'm pretty sure all defenders come with Bosch AGMs no? |
6th May 2024 5:33am |
Ian can you confirm MultiCAN-566 MHLastUserMode set to enabled does not work for p400 MHEV models? If so might be worth adding a footnote in the summary page to keep people informed, thanks!
6th May 2024 5:46am |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 172 |
Thanks for the reply, to help “dukluck”,I need to know US market premium headlight hardware. For this reason I need the photograph of the headlight ecu scan. I know very well the various differences in headlights on the European market, I have successfully retrofitted the matrix on my Defender, and helped other European users to succeed. When, as in this case, a major failure problem arose, it was always due to an incorrect hardware problem. I await support from the forum, possibly also in pm. Marco Click image to enlarge |
6th May 2024 5:54am |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 109 |
It works fine on my p400 MHEV. |
6th May 2024 7:45am |
carltb Member Since: 06 Oct 2023 Location: Sweden Posts: 62 |
I can't even see the
MultiCAN-889 GSR2 EU Market Ft using my G3. Even when showing unsupported. 2024 p400e 2025 Defender 130 V8 (DOA, new one coming) 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
6th May 2024 10:49am |
Do you have the latest firmware? |
6th May 2024 11:43am |
Ah, that could be a factor. I'm on version 4.2.3 Build 176
Latest? 2025 Defender 130 V8 (DOA, new one coming) 2025 Defender 90 D250 (wifes) 2024 Defender 110 p400e HSE (sold) 2015 Defender 110 Double cab 2004 Defender 90 Td5 |
6th May 2024 12:16pm |
hthagood Member Since: 26 Jun 2023 Location: Texas Posts: 4 |
Disappointing. |
6th May 2024 7:52pm |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 |
I don't know whether it works or not on the P400 but will add a note to let people know Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
6th May 2024 10:29pm |
6th May 2024 10:31pm |
Looneyfitter Member Since: 03 Mar 2024 Location: Liverpool Posts: 30 |
. I believe you need the larger screen for it to work |
7th May 2024 6:59am |
hmgt3 Member Since: 13 Nov 2023 Location: MCT Posts: 3 |
Hi. I have a 22 V8. I think for our country traffic sign recognition is turned off. Does anyone know how to turn this feature on using the GAP tool?
Thanks in advance. |
8th May 2024 4:33am |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 434 |
I managed to change the alarm setting, Interior sensors.
Struggled 3 years now with it when my dog was in the car. In the manual, 1st lock does not engage the interior sensors, for my country the first lock engages the interior sensors. I needed to disengage the interior sensors always before in the Pivi menu with running engine. So finally I can keep my dog shortly in the front with Windows partially opened whitout thinking before to change the settings Multican 563. AlrmSensoronSingLock = Single Lock Changed to - No Alarm Sensors on Single Lock. ( This setting could be region dependent, I know for the Netherlands and Germany at least) No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. Last edited by Defendit.. on 29th May 2024 3:21pm. Edited 1 time in total |
8th May 2024 7:30am |
Ratledge Member Since: 17 Jun 2023 Location: Murchison NC Posts: 28 |
Just keeping up and for notes, the Parking Assist works up to the point when Start is greyed out.
The GSR2 setting does nothing for my MY23.5 D90S P300. Has anyone figured out how to force headlights on, like required in Denmark? |
8th May 2024 4:17pm |
