Home > General & Technical (L663) > Who's changed their oil
Page 4 of 7 <1234567>
ODPA
United States
When you do your own oil change how do you reset the service mileage? I did the reminder reset which worked fine but the Pivi still shows a few miles until service? I thought the reset would take care of both? Is this a dealer reset or GAP tool reset? Or am I just missing something.
Post #1033772 4th May 2024 2:41am
DrRob
My understanding is that service interval should be reset on every oil change as it’s resets the oil dilution calculations etc. If you didn’t reset it then it has no idea new oil in the engine and will ask for next oil change sooner. This is how my old 4.4 tdv8 L322 worked so no reason a Defender will be different.
A GAP IID will reset it and much more. Invaluable it imho Bow down Thumbs Up MY25 90 D350 X-Dynamic HSE in Silicon Silver and coil sprung
1974 Series 3 Lightweight = "Millie"
Many Range Rovers and Land Rovers over the years 😂
1949 80" - still in family since 1975
Post #1033863 5th May 2024 2:44pm
ODPA
United States
I think you gave me the answer I was looking for. I have the GAP tool but have not looked to see if it allows me to do what I was asking. I will take a look this morning and see what I can do with it.
Post #1033868 5th May 2024 3:40pm
Retroanaconda
You can reset the service interval in the IIDTool yes.
Post #1033881 5th May 2024 5:25pm
sasdiscos
My last van. A transit. Just had the standard ford service from new. 20 k or 2 years.
It did 180k with no issues at all. And as far as I’m aware it’s still running.
Oil must be much better nowadays. And engine build quality.
Steve.
Post #1033896 5th May 2024 7:27pm
ODPA
United States
Can anyone share how this is done? When I look in the GAP manual it references the reset procedure I already did which does not require the GAP tool. Power on, open driver’s door, open hood/bonnet, press brake then accelerator and hold for 30 seconds. I have done this which the system says it is resetting but the Pivi still shows 1300 miles until next service. Do I have to wait for it to actually reach the service interval? I would really like to have the interval set to near when I changed the oil. I guess I am not understanding how I use the GAP tool to reset this. Any help would be greatly appreciated.
Post #1033910 5th May 2024 10:48pm
lightning
Steve.
You're probably right to be honest, but it certainly does no harm to change the oil more often. Personally l do a lot of short journeys so am not happy leaving it 20,000 miles.
Post #1036875 8th Jun 2024 9:55pm
Moo
Ukraine
My original 2005 D3, owned from new, had done 231,000 miles when I sold it. It's still going strong and I only ever changed the oil as per LR's service schedule. In fact all my other D3 and D4s are still going strong and were only ever serviced as per schedule.
Many people on the Disco3 forum religiously changed their oil every 5-6000 miles, some still do, but it seems to have made no difference to crank failures the 2.7 and particularly 3.0 engines suffer from.
Modern lubricants are very different to what many of us previously knew and are designed to meet the requirements of longer service intervals that manufacturers and lease companies require. I'll just keep mine as per LR service spec. And I plan to keep it 10 years + Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1036876 8th Jun 2024 10:40pm
I think some people over do oil changes for sure, I usually go by the typical LR schedule and when the oil gets dark.
You can usually tell and know when it’s needed.
It’s things like the Diffs etc that’s more of an issue because they aren’t quite as easy to check. Often get left longer than should be.
I wouldn’t want to replace a Diff often that’s for sure, especially on the front plus there’s the transfer box and gearbox as well. TheThunderRolls🇬🇧🇺🇸
Post #1036877 8th Jun 2024 11:24pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I haven't got my car with me at the moment but it should be along the lines of
Service menu > IPC > reset service message Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1036878 9th Jun 2024 12:33am
abyss
Australia
Used my GAP tool to set the max height on air suspension. I was able to undo the engine undertray (with million of bolts) and drain the oil without lifting the car at all.
Pretty easy and no brainer that the cost of oil and oil filter is same as a full tank of petrol.
Post #1036991 10th Jun 2024 5:18am
johnlad
So what oil is recommended for the D300
Can’t find any information.
Post #1037550 15th Jun 2024 7:54pm
roccobarocco
Germany
Post #1037552 15th Jun 2024 9:28pm
johnlad
Thanks
Post #1037553 15th Jun 2024 9:34pm
roccobarocco
Germany
Welcome, you will need 9,5 Litres for a full oil change
Post #1037622 16th Jun 2024 7:09pm
