Home > Technical > Defender td5 play in turbo? Bad sensors? |
Djmdaniel Member Since: 16 Jun 2023 Location: Northamptonshire Posts: 12 |
Hi, my defender td5 2002 90 struggles on acceleration and its hard to get it above 65
Just trying to figure out why at first the E pin on the boost waste gate was misidentified so i thought it could be that but that hasn’t changed anything so iv removed the pipe and this is how much play is in the turbo? https://youtube.com/shorts/RiOVoXMCk6Q?si=RBrYZYcsiU8VukQ3 Is this normal and would this cause a lack in power when accelerating? The problem of the lack in power started after I had my clutch and flywheel changed, at first i thought it was the crank shaft position sensor+ cables as I could see a bit of damage on them, so i fitted a new sensor and cable loom but this didn’t change anything, any ideas of anything other sensors that could have gotten damaged? Thank you |
26th Apr 2024 6:45pm |
No damage and it spins freely
26th Apr 2024 7:46pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5690 |
Obvious but I will say it.
You aren’t stuck in low on the trans box are you? |
26th Apr 2024 7:48pm |
I can hear it go from high neutral and low and low feels like it’s in low and high in high if that makes any sense
26th Apr 2024 7:49pm |
