![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
nebc100 Member Since: 07 Nov 2023 Location: Altlinster Posts: 98 ![]() ![]() |
PLEASE let us know what options you activated so we can try and get it working in our vehicles!!
Ratledge Member Since: 17 Jun 2023 Location: Murchison NC Posts: 28 ![]() ![]() ![]() |
[quote="PeteSkeet"]
Just.turning the front wheels so they stop on the curb if the brakes fail instead of down the street. Old school thing to do, we don't worry about it as much as we used to. |
Tonydr Member Since: 20 Apr 2024 Location: Naples Posts: 3 ![]() ![]() |
Hi, I picked up my Defender 110 D200s 3.0 in February 2024. I was very convinced that I could start the engine remotely via the Incontrol app but unfortunately this wasn't the case. I called the Land Rover assistance center and they told me that in some countries, including Germany where I live, it is not possible to have this option. So I would like to ask if it would be possible to activate this feature with the GAP diagnostics IID tool.
I would also like to know if it is possible to activate the memory function for driving assistance, otherwise I have to reset to Custom every time I restart.[/b] |
GavinC Member Since: 23 Apr 2024 Location: Washington USA Posts: 7 ![]() ![]() |
[quote="Ratledge"]
Yes I do that when parked on a slope. Old habits. Just never heard the word before. |
Park assist settings Activate Park Assist EUCD-059 Parking Assistance Standard: Without Parking Assistance Change to: PDC (Front, Rear) - Parking (Parallel, Exit) EUCD-099 Park Assist Camera Standard: Without Park Assist Camera Change to: With Park Assist Camera EUCD-140 Pdcautoactivationmenu Standard: Not supported Change to: With PDC Auto Activation menu MultiCAN-469 PDCAutoActivation Standard: Not Supported Change to: Default OFF configurable MultiCAN-500 PDCBtnFCIM Standard: Not supported Change to: Fitted MultiCAN-602 PDC Standard: PDC not fitted Change to: 10 Channel fitted ( Park Assist) MultiCAN-786 Park Assist Standard: Not Fitted Change to: Full Auto VarD (Fully automated park assist with automated steering breaking acceleration and gears) Needed 2 resets to PIVI for the app to appear in PIVI and a full car shut-down to clear the "Emergency Brake Assist Unavailable" error. |
Looneyfitter Member Since: 03 Mar 2024 Location: Liverpool Posts: 30 ![]() ![]() |
Does this also enable steering assist when using Acc my D5 used to put a green steering wheel above the lane assist lines when activated.
forzahog Member Since: 03 Nov 2022 Location: Fayetteville Posts: 66 ![]() ![]() ![]() |
Could you check your DADC values under "ECU Infos" on the IID app? I have tried the settings above, but I just get a blank parking app and no auto activation. Here is what my DADC has for comparison. DADC ECU Info Assembly (F113) MY42-14E159-AG Calibration (F124) M8B2-14E157-AF Hardware (F111) L8B2-14E158-AF Strategy (F188) MY42-14E153-AF 20MY Defender 110 Fuji White |
![]() Click image to enlarge No data available I’m afraid. Ignition on or off. No data. |
Mine says that as well, but if I tap on it I get the info for that module. 20MY Defender 110 Fuji White
Nashvegas Member Since: 25 Dec 2021 Location: Portland, Oregon Posts: 40 ![]() ![]() |
Has anyone with a 2020 gotten this park assist to work?
G4 user here. So on my 2020 110 X I am also getting the blank park assist app, ie when I see the icon in the bottom row of the app list and press the icon, the Pivi screen just has the steering wheel with a small P next to it dead center, like the App isn't loading or something (and no icon on the side of the main pivi screen to select). Have tried lots of variations on the CCF settings to no avail. Here's my DADC ECU info per your request. I'm wondering if this isn't going to work on 2020 cars? Others with 2022+ cars seem to work. ID: 1416 IP: 169.254.56.84 Assembly (F113) MY42-14E159-AG Calibration (F124) M8B2-14E157-AF Hardware (F111) L8B2-14E158-AF Serial 5325800672009121 Strategy (F188) MY42-14E153-AF ![]() Click image to enlarge |
Mine is a 2024 XS and it doesn’t work.
I noticed though that I have 12 sensors (6 front and 6 back) so I tried it on the 12 channel option, but it hasn’t changed anything. The car sees the spaces, and starts the application but the START button is greyed out. |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 111 ![]() ![]() |
If you email yourself the ECU info, I believe it will be there. |
I don't believe so. Not yet anyway. It looks like our DADCs are the same and I'm getting the blank park assist app as well. I'm going to try the 12 sensor setting and see what I get. Even if I get the non-functioning start button, that's progress. ![]() |
Did it enable steering assist when using Acc? |
