Home > Maintenance & Modifications > Brake and clutch fluid quantity
As title, how much quantity would be required for a proper flush and replacement of the brake fluid and clutch fluid?
Would 1L be cutting it a bit fine, especially seeing as a good flushing would be ideal?
Iโ€™m tending to think that 2L would be a bit safer, but is that way over the top?
The clutch system doesnโ€™t take much at all, but there is losses with flushing both brake and clutch fluid through. KEEP CALM AND Drill ON
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1032433 22nd Apr 2024 5:56pm
Ianh
I think most can get away with 1ltr for the brakes, but if going for a good flush of brakes and clutch then 1.5l would be about perfect.
However given the price of DOT 4 it will only be a couple of pounds more to get 2Lโ€™s and that way you know you will not come up short on the day.
Post #1032444 22nd Apr 2024 6:53pm
Zed
Yep, what Ian said. Last time I bought 2 litres to do the job and had a bit left which I keep to top up my very slightly leaky clutch. WARNING.
Post #1032446 22nd Apr 2024 7:03pm
Good to know, thank you. I did think 1L would be pushing it too far to do both brakes and clutch fluid.
So thank you for clarification so 2L will be perfect.
I think a flush is a good thing for longevity anyway, I have a little LED tester for it (the fluid) for moisture content and is current about 1 or 2% so imminently due for doing for the bi-annual fluid change.
Thumbs Up KEEP CALM AND Drill ON
Post #1032447 22nd Apr 2024 7:05pm
Yeah, probably 400ml to 100ml left.
What do you think is leaking on yours ? Hopefully not the Slave. KEEP CALM AND Drill ON
Post #1032448 22nd Apr 2024 7:06pm
Zed
Unfortunately I think it is the slave. Itโ€™s a very slow leak but will need doing at some point. WARNING.
Post #1032451 22nd Apr 2024 7:16pm
Ah thatโ€™s a pain, I had one that had a pin hole of a leak in the diaphragm.
Be sure the bleed valve is shut though and not weeping, they arenโ€™t very strong, but all the same any tiny bit of pressure loss or leaks could do it so any moist areas you never know. KEEP CALM AND Drill ON
Post #1032452 22nd Apr 2024 7:23pm
