Home > Puma (Tdci) > Stuck in gear ( I think!)
Packster82
2013 Defender 110 Puma 2.2 CSW Keswick Green
Hi guys,
M 110 puma was parked up for a few days, when I went to drive it really didnโ€™t want to find first gear, after some not so gentle persuasion I got it into gear but it was third. The gear stick selector goes back to neutral but seems the truck seems to be stuck in third gear. It stalls when clutch is released and finds a very faint bite from a standstill which tells me itโ€™s third.
Any ideas??
Thanks in advance.
Alex
Post #1031557 14th Apr 2024 7:50pm
Clutch spring fell out, or fluid leak, if no signs of leaks or fluid loss then a clutch spring gone is even more likely.
Check the fluid quantity and for any leaks, but if not, it may be a new clutch needed unfortunately.
Do you know which one it is? (Brand). $W33T $0U7H3RN $UG4R
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #1031559 14th Apr 2024 7:57pm
Packster82
Thanks, will have a look. I really hope itโ€™s not the clutch as just had a new one out in! Not sure which one but will find out. Will keep you updated.
Post #1031563 14th Apr 2024 8:14pm
Good luck. Thumbs Up Hopefully all will be well, if itโ€™s recent you might want to con at them if itโ€™s so new. $W33T $0U7H3RN $UG4R
Post #1031569 14th Apr 2024 8:56pm
IT's not unusual for the MT82 to get stuck in gear, but it is usually first and is caused by a deficiency in the detent devices on the 1/2 select shaft. I've not hear of one getting stuck in third though.
If you search the forum for "stuck in gear" threads you will find the solution (to the 1/2 problem at any rate).
Post #1031575 14th Apr 2024 9:46pm
HardCharger
I had this issue, difficulty selecting then eventually stuck in 3rd. Had to drive in low range and the smell of burnt clutch filled the air. Had to have the Defender put on a flatbed to the mechanic. When the mechanic opened up the box, clutch was obviously kaputt but was in utter horror when he opened the rest of the box to find the gears ground down with sludge (oil + metal bits from the gears).
Needed a new gearbox, luckily, I remember a friend of mine covered to and auto transmission and contacted him for his barely used MT82. It is now on my truck. The mechanic used a synthetic GL-4 oil but not sure if it's the same spec as Ford rated so plan to source proper oil and do a drain and change.
Post #1031584 15th Apr 2024 2:41am
