Home > Td5 > A squeaky tale |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 635 |
Inspect the squeaking belt - I have found rubber debris embedded in the valleys of the serpentine belt - the debris shows up as shiny strips, this seems to cause the squeaking as it runs over the pulleys. I got totally fed up with an old 300tdi that was used very rarely, but when used it would do 600 mile round trips, I replaced tensioner, alternator, water pump and front timing case, each time it would run quiet with a new belt for the first hour or so and then start squeaking again, every time caused by a build up of rubber debris in the belt.
I fitted new pulleys throughout to the existing ancillaries and it has run silently for the last six years- my theory is that the old worn pulleys had rust pitting from the lack of use of the vehicle, and the pitting caused abrasion to the belt and the subsequent rubber debris |
23rd Mar 2024 3:42am |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5883 |
I have ordered a new belt as the old one I found was a few years old. Dayco belt on the way. 1999 Defender TD5 110
24th Mar 2024 3:29pm |
Chriswb84 Member Since: 16 Sep 2023 Location: North West Posts: 22 |
Mine didn't look too bad, but one of the bearings on one of the pulley's failed on the M56, and it was a lift with the AA. I cant remember it costing a lot of money to replace all the pulleys, tensioner and belt. At the time I wish I had replace them sooner. Certainly cheaper than the additional miles charge by the AA to get home.
25th Mar 2024 12:24pm |
M94PUMA Member Since: 16 Dec 2016 Location: Hampshire Posts: 132 |
Recent purchased td5 had a squeak when cold for the first 5-10mins and when turned off has the usual td5 chirp noise. I was 100% sure it was going to be the crankshaft dampener.
Thought I’d just re-fresh the belt, genuine tensioner, 2x new idler pulleys before spend big money on a genuine dampener.. Cold start engine squeak noise gone, result! And also the normal noise when turning off the engine when hot which I had money on being the crankshaft dampener. |
2nd Apr 2024 5:02pm |
New belt fitted and I think the squeal has now left the building! 1999 Defender TD5 110
3rd Apr 2024 7:22am |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2109 |
Great news 👍
You’ll now be able to hear that ‘other noise’ that will drive you mad… |
3rd Apr 2024 9:44am |
Yea there a few of them..... 1999 Defender TD5 110
3rd Apr 2024 10:41am |
