![]() | Home > Td5 > Loud clacking and smoke |
As a starter for 10 I would take off the valve cover and check that all is as it should be. Pay attention to the rockers/valves and if the timing chain is still tensioned.
Good luck ![]() |
Inguz Member Since: 06 Sep 2020 Location: In the wild Posts: 101 ![]() |
Took the cover off this morning and found one of the guide rails is cracked. I'm guessing this is the problem, or least I hope it's nothing more serious. I will swap it out and may do the chain while I'm at it. I see mixed reports that the chains don't need to be done and they should be done at 200k. Anyone have any more info on this?
Bingo mate...
![]() As to the timing chain, it is dealers choice. As you have found some say yes some say no. If in doubt inspect it and the guides for wear and replace as necessary. My TD5 has well over 200k miles and the guides and chain are in fine fettle, but others with less than 100k miles may have had premature failures. Sorry for your troubles... But it is best to thoroughly examine the engine for damage before throwing parts at it. |
The rocker arms are fine, I meant one of the timing chain guide rails is broken, most likely from just wear.
I've ordered a new one and hope to fit it without removing the head or sump. |
Ah ok well that would also make a lot of noise. IIRC there was so early TD5s that suffered from timing chain guide failure. Just one warning though, check the timing marks are in the correct position when you install the new chain and guides. Also, check that the engine turns over by hand cleanly before starting it for the first time.
I’m almost done with taking the timing chain cover off. I’ve got the stump off but the long bolt on the cover the goes into the head is preventing me from finishing the job.
It’s looking like I have to remove the head, which I don’t want to do. I seen a few reports of people doing this without removing the head, does anyone know how? Can that bolt be removed? ![]() Click image to enlarge |
Answering my own question here for future viewers. I looked on LR Workshop and the part number shows a double threaded bolt.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1121 ![]() ![]() ![]() |
A double threaded bolt? AKA a stud?
Yes a stud
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17558 ![]() ![]() ![]() |
I was given a box of large socket head capscrews some years ago, surplus to requirements, which turned out to be genuinely double-threaded, - they had twin-start threads. I have no idea what they were bought/made for.
They only use as far as I can tell are for practical jokes. |
sasdiscos Member Since: 22 Jul 2023 Location: UK Posts: 155 ![]() ![]() |
Some masonry bolts are double threaded. Direct into concrete.
Indeed. What makes my SHC unusual is that they have conventional thread forms, so the pitch, profile and dimensions match conventional single start threads, but being twin start no conventional nuts fit them (I can't offhand remember the size, but they are big, something like M20). They are very strange, and I really cannot imagine what they were made for. They must have cost someone quite a packet, but are now useless except as novelty items.
It took me quite a while to work out why nuts didn't fit! |
