![]() | Home > Maintenance & Modifications > 300 TDI Main Harness |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 828 ![]() ![]() ![]() |
The harness will also need to be R-o-W spec too as it is for 300tdi which in 2000 would have been shipped with the Td5 for UK/Europe sales.
Francisco Member Since: 25 Sep 2020 Location: Parana Posts: 10 ![]() ![]() ![]() |
Could you explain for me what is r-o-w ?
Sorry, Rest of World. Landrover (and probably other manufacturers) use the term to describe a lower spec vehicle with older tech or simpler emissions systems that they cannot sell in their normal markets but can still export to countries with less strict rules (usually Africa or South America.
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 363 ![]() ![]() ![]() |
Try: https://www.lrworkshop.com/
And have a look at this: ?si=nbEsnXNtxaDeDu5m |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 197 ![]() ![]() ![]() |
Hi Francisco
I've seen your post on LR Workshop and will try and extract some more detail for the 99-02 bulkhead looms, then reply in more detail. Just so you know, the 300Tdis never had ABS so there won't be a loom with that feature, although it has been retrofitted with custom wiring by some people. Also, as your profile says you're in Brazil, it's worth checking if your VIN starts SAL (Solihull built) or 93R (Brazil built). The Brazil ones had some different bits fitted. Will LR Workshop Find a Defender's history and spec: https://defender.lrworkshop.com |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1679 ![]() ![]() ![]() |
Might be worth talking to
https://www.autosparks.co.uk/ |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 496 ![]() ![]() |
Would'nt waste your breath.
Best option is late TD5 full option harness and combine the two harness's.
Well, about the VIN number, that's always been a problem. This car was assembled in Brazil. So the vin number is not tracked by British suppliers. But yes, you got it right, my number starts with 93 |
Yes, I'm thinking about it. Can you tell me which is the code for the most complete harness for the td5? |
