Home > Maintenance & Modifications > 300 TDI Main Harness
Francisco
Brazil 2000 Defender 90 300 Tdi CSW Chawton White
Hello
To save time and not bore anyone, I'll get straight to the point and tell you what I want to know:
I need to know which is the most complete wiring harness for a Defender 300 TDI.
The last question is whether anyone can tell me where I can find the label with the code for the engine harness and the main harness.
Perhaps the best answer would be to provide me with a link that has all the harnesses with their functions and connectors.
The LR Workshop diagram is very useful but the information is insufficient for what I need.
In case you're interested, I have a Defender 90 (year and model 2000) It comes equipped with a few things including air conditioning, radio, rear defogger, rear windscreen wiper.
What I want to do is add various options that aren't in the car. But I'm going to do it as standard. Electric windows, electric locks, third brake light and alarm centre (preferably A 10) are the initial goals. To avoid improvisation and splicing, I'm thinking of changing the original wiring harness.
I think that in this case, the best approach would be "the more, the better". I believe that having the most complete harness possible is useful, even if there are connectors left over. I'm thinking of leaving it available to add abs, traction control and an EGR valve at a later date.
The most complete harness I have is YMC002503. But it doesn't have ABS.
If anyone would like to help me, please ask me what you need.
*must be LHD
TY
Post #1029012 22nd Mar 2024 7:37pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
The harness will also need to be R-o-W spec too as it is for 300tdi which in 2000 would have been shipped with the Td5 for UK/Europe sales.
Post #1029027 23rd Mar 2024 12:29am
Francisco
Could you explain for me what is r-o-w ?
Post #1029028 23rd Mar 2024 12:32am
I Like Old Skool
Sorry, Rest of World. Landrover (and probably other manufacturers) use the term to describe a lower spec vehicle with older tech or simpler emissions systems that they cannot sell in their normal markets but can still export to countries with less strict rules (usually Africa or South America.
Post #1029034 23rd Mar 2024 6:46am
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
Try: https://www.lrworkshop.com/
And have a look at this: ?si=nbEsnXNtxaDeDu5m
Post #1029051 23rd Mar 2024 11:31am
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
Hi Francisco
I've seen your post on LR Workshop and will try and extract some more detail for the 99-02 bulkhead looms, then reply in more detail. Just so you know, the 300Tdis never had ABS so there won't be a loom with that feature, although it has been retrofitted with custom wiring by some people.
Also, as your profile says you're in Brazil, it's worth checking if your VIN starts SAL (Solihull built) or 93R (Brazil built). The Brazil ones had some different bits fitted.
Will LR Workshop
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1029063 23rd Mar 2024 1:45pm
NickMc
Might be worth talking to
https://www.autosparks.co.uk/
Post #1029083 23rd Mar 2024 6:46pm
Linds Hanson
Would'nt waste your breath.
Post #1029225 25th Mar 2024 1:06pm
Linds Hanson
Best option is late TD5 full option harness and combine the two harness's.
Post #1029226 25th Mar 2024 1:11pm
Francisco
Will@LRW wrote:
Hi Francisco
Will
Well, about the VIN number, that's always been a problem. This car was assembled in Brazil. So the vin number is not tracked by British suppliers. But yes, you got it right, my number starts with 93
Post #1029229 25th Mar 2024 1:49pm
Francisco
Yes, I'm thinking about it.
Can you tell me which is the code for the most complete harness for the td5?
Post #1029261 25th Mar 2024 4:40pm
