Home > In Car Electronics > Alternative to double DIN
Page 2 of 2 <12
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Having own a number of "modern" cars with an all signing infotainment system, I found that I never used any of the cool features. For my Defender satnav I use an iPad mini on a RAM mount. This gives me a large screen with plenty of detail without messing about with the dash.
I sort of followed the hints and tips from here https://www.snayps.com
Less expensive and of course you can use the iPad for other things.
Post #1023125 31st Jan 2024 4:54pm
Zed
I was going to take a punt on one despite it being older tech and not having wireless CarPlay but it turns out the OBD functions are not compatible with pre 2011 vehicles. It’s a real shame as it’s a much more elegant solution than the usual double dins. I guess I’ll wait to see if they make a new compatible version but it looks unlikely. It also seems the OBD functions are hit or miss even with post 2011 vehicles and Stinger have yet to find out why or offer a solution. WARNING.
Post #1024730 14th Feb 2024 6:13pm
jst
Has anyone on here actually fitted one of these or tried one Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1028329 17th Mar 2024 9:03am
Zed
Stinger say they have now made the unit’s OBD functions compatible with pre 2012 Defenders. WARNING.
Post #1028635 19th Mar 2024 1:24pm
It does have CarPlay and works with Android, that’s irrespective of OBD2 functionality.
Mentioned here https://stingerelectronics-eu.com/product/...1810e-lr1/
RHS mid screen. Thumbs Up
So that means you have google maps, Tom Tom go, waze and other nav options powered by phone app whichever side the fence you use.
Which is the same as what my Pioneer has, only thing I can see differs with the Stinger is, bigger screen, physical LR dash button layout different, and HDMI.
Those three things are positives compared to what I have now, if from a 2 din you don’t need the side cut out for switches.
If it was the same price as Pioneer or just a little more, then I’d consider it for sure, the extra price is a little high imho for those features but there is a lot included and if you factor in what some manufacturers would charge for factory navigation it’s cheap. TheThunder Rolls🇬🇧🇺🇸
Post #1028659 19th Mar 2024 4:53pm
Zed
It doesn’t have wireless CarPlay though. That means it either has to be plugged in to the USB all the time or you have to buy an extra adapter. Not a huge issue but it just shows the unit is already showing it’s age. Sound quality seemed ok but hard to tell for sure as I was listening in someone else’s Defender. WARNING.
Post #1028681 19th Mar 2024 6:07pm
There is that yes, but you do get some (little / barely at all noticeable audio losses).
Overall wired is more reliable and better quality, I use wired because I know it’s connected.
When you go BT or Wi-Fi or whatever connection method it can take up more time than it’s worth.
Some systems auto pair (auto connect).
But if your in a rush you can bet that it’ll be not connected or one of the settings is off.
Usually and likely on the phone side as it wastes battery a lot, especially BT.
I guess they did that if someone wants the add on they can have it, to bring the overall price down.
At least Bluetooth audio and calling etc has improved a lot in recent years, at one time many were very hit and miss. So much so, often they weren’t even usable.
Thumbs Up TheThunder Rolls🇬🇧🇺🇸
Post #1028693 19th Mar 2024 6:54pm
Baytown
Australia 2012 Defender 110 V8 Petrol CSW Auto Blenheim Silver
Im just fitting mine now to my 2012 110 here in Cairns Australia.
It’s beautifully put together and yes, you blank off the two centre aircon vents, and you loose the factory analogue clock.
You also have to cut part of the dash away, the horizontal section of the dash above the factory stereo cut out, and two redundant sections.
I’ll post my views after I finish fitting it. Im currently finishing fitting my Optimil washer replacement but have been stuck trying to fit the hose connector to the new 6 jet nozzle. A mongrel of a job!😕[/b] 2012 110 LS3 6.2 V8 - 6 Speed Auto
Post #1038253 24th Jun 2024 9:01am
Andyslandytd5
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
How did you get on with the Stinger Baytown?[/quote] 2015 Puma 2.2 110 XS Utility Station Wagon - 2024 - Present
2004 TD5 90 XS Station Wagon - 2019-2024
2003 TD5 90 G4 LE - 2009-2010
1990 Ninety 6.2 V8 Station Wagon - 2006-2009
Post #1041479 31st Jul 2024 1:40pm
Page 2 of 2 <12
