Home > Technical > TD5 HELP!!! |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3469 |
The achilles heel of the Td5 is the oil pump bolt. If that undo itself, you will be left with no oil pressure and catastrophic failure of the engine.
If that is the case, it is more being unlucky rather than something you have done. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
29th Feb 2024 4:33am |
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 211 |
Take the sump off and check the oil pump bolt as mentioned above 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
29th Feb 2024 7:26am |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
As the others have said 1st order of business would be to drop the sump and check the oil pump bolt.
Second would be to remove the intake hose and check the turbo impeller to see if its intact and if the engine has ingested it. Not totally local but my father in law uses these chaps and they always have a fair few Defenders in. https://venture4x4.co.uk/ Last edited by kenzle8a on 29th Feb 2024 8:01am. Edited 1 time in total |
29th Feb 2024 7:59am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1116 |
Or maybe the engine was old and tired from poor maintenance before you, maybe someone ran it low on oil or maybe it is not the original engine.
Was your oil level correct, did you maybe starve the engine from oil when you were at your pay and play site? Regardless if you rely on others to keep your Defender in tip-top shape it will be an expensive experience. Not saying you should swap your own engine out, but for sure going to a garage for everything quickly doubles the money you spend on the car. |
29th Feb 2024 8:00am |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1432 |
You have pm
29th Feb 2024 8:19am |
Nickthedefender Member Since: 15 Oct 2023 Location: Market Harborough Posts: 12 |
Thanks Jim.
29th Feb 2024 9:33am |
Thanks. I have checked the turbo and it is missing some sizeable chunks of the fins. As for the dreaded bolt, that hasn’t been checked as the garage said it’s very likely the engine has suffered heavy wear and damage. Don’t really know the best way forward at this stage. Tempted to buy a secondhand turbo and to remove sump and check/replace the bolt and see what happens, just don’t want to waste my time and money if it’s shot. |
29th Feb 2024 10:09am |
If your missing vanes from turbo, and metal in oil it certainly sounds engine side’ and passed through the turbo with exhaust gasses. Realistically as I guess it’s a keeper, only one solution….
Engine swap inc turbo. Budget option would be for a known good used swap. Me I’d strip it fix the bits needed, upgrade stuff and happy days A td5 is usually pretty bullet proof… just regular oil changes and filters. |
29th Feb 2024 10:21am |
29th Feb 2024 10:31am |
Well a new turbos on the list I’d be going variable vane for the replacement.
29th Feb 2024 12:43pm |
I would have the same temptation, although I would not get a replacement turbo before taking off the sump and check the oil pump bolt. Depending on the extent of the damage, but you could possibly get away with just a bottom end rebuild. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
29th Feb 2024 1:10pm |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 535 |
If you are after a standard turbo, I have a pair of secondhand ones I am willing to sell. £50 each plus postage. |
29th Feb 2024 1:41pm |
Tank Member Since: 25 Jul 2014 Location: Fife Posts: 431 |
Hi
So, the same thing happened to me. My oil filter housing cracked and I lost all the oil. It was supposed to have been checked by the garage when it was in for a service and checked for oil leaks. Turned out to be a crack in the oil filter housing which they didn't see! Anyway, turbo did the same thing but none of the bits got in the engine. Cleaned all the bits out and fitted a new turbo and the Tank has run fine ever since, that was about 9,000 miles ago. 225,000 and still going strong. So far ! Tank |
29th Feb 2024 4:42pm |
So that’s the worrying thing, I didn’t lose any oil, it’s still at the full mark with very fine metal fillings in!
29th Feb 2024 7:36pm |
