Home > Wheels & Tyres > KN Predator
the_lincs_landies
KN Predator
Hi All,
I am lead to believe the wheels on my Defender 110 are made by KN (which it appears are no longer trading as far as I can tell) and are the Predator model in a 17" Alloy Wheel (see image below).
All 4 of the wheels are really old and tired (chipped paint, oxidation etc.), and could do with a refurb - but then again, so are the nuts. One of the nuts is missing from the spare, and I have had no luck finding the "specialist" nuts:-
funrover.com wrote:
the nut actually wraps around the stud and is sandwiched between the wheel and stud
Does anyone know where I may be able to get hold of these nuts, so I can get the wheel refurbished, or am I better off cutting my losses, selling these wheels, and getting new wheels?
Thanks in advance Smile
Kieren
Post #995454 7th Jun 2023 3:01pm
Mossberg
United Kingdom 1993 Defender 90 300 Tdi HT Aintree Green
Have you tried a standard defender alloy wheel nut?
Post #995459 7th Jun 2023 3:33pm
mwestcrew
United Kingdom 2011 Defender 130 Puma 2.4 HCPU Baltic Blue
I run the same wheels on my 130.
A standard wheel nut doesn’t fit at all, the nuts seem to be special to the wheel.
I believe that these wheels were only sold in the UK by John Craddock (I bought a set in 2003 from them) so it might worth speaking to them.
Let me know how you get on if you do please.
 2011 130 Utility Body
2005 110 Van
Post #995466 7th Jun 2023 4:18pm
the_lincs_landies
Yeah, I ordered a full set to replace them not having the sense to check them first
Will give them a message in the morning, will let you know if I hear anything. John Craddocks do come up when you google the wheels but as a discontinued item, which is why I wonder if KN Alloys are still trading at all.
Post #995479 7th Jun 2023 6:17pm
the_lincs_landies
Emailed them today, got an email back within the hour saying they couldnt get the nuts for those wheels.
Post #995575 8th Jun 2023 12:42pm
Chris S
You could get some like Wrington to make them for you, not sure of the cost. Just an idea.
Post #995579 8th Jun 2023 1:56pm
the_lincs_landies
I had thought about it, will look into it though now I know I cant get them. If its too much I'll just get new wheels.
Post #995583 8th Jun 2023 2:13pm
camelman
If they are 24mm, Twisted do them to fit their sports wheels and look like they are the same as yours.
You'll have to shell out £130 though
https://www.twistedautomotive.com/store/product/the-sport-nut/
Post #995584 8th Jun 2023 2:21pm
camelman
Have you checked the alloys are load rated for your 130? Most alloy wheels aren't as they need to have at least a 1100kg rating. 110s don't need that high a rating as the rear axle has a lower weight capacity.
Post #995586 8th Jun 2023 2:29pm
the_lincs_landies
Still too short sadly, I'd looked at these. Almost the entire thread is covered by the cylindrical part, then the entirety of the head sits proud from the wheel.
The wheels need a refurb anyway, so I may just cut my losses, get some new wheels, and sell these wheels and nuts to someone on the cheap for them to refurb and tidy up the existing nuts. By the time you take tyres out of the equation there isnt a lot to be saved.
Post #995587 8th Jun 2023 2:30pm
Bps
Wheel nuts
Try wrington im sure they might do them.
Post #995633 8th Jun 2023 5:06pm
the_lincs_landies
Thanks for the suggestions, Will drop a line to Wrington about a cost for having some machined, checked the website and they don’t have the relevant ones “off the shelf”
Post #995635 8th Jun 2023 5:10pm
Norfolklandy
Did you have any luck?
Did you have any luck finding any? I’ve just brought a set of alloys but I’m missing 2 wheel nuts 🔩
Would be great to be able to get them on my 90
Post #1019681 30th Dec 2023 9:56pm
Andreaschristensen
Denmark 2000 Defender 110 2.5 TD CSW Keswick Green
Hay
I am my self running KN Predator like yours, but I have with out any luck been looking for a reserve wheel. If you have any luck in your search please let me know alternatively if you give up the search and am interested in buying the best of you old wheels. Kind regards Andreas
Post #1026211 27th Feb 2024 8:52pm
the_lincs_landies
No luck I'm afraid, and I no longer have the car Sad
Post #1026326 29th Feb 2024 7:53am
