Home > Technical > TD5 electric window kit, switch change to carling contura II
BobC
United Kingdom 2003 Defender 110 Td5 HT Epsom Green
I recently bought and fitted one of the readily available kits for electric windows. The kits are essentially all the same . Fitted and all worked ok bar one of the switches which was defective. Being a cheap 5 pin switch, Chinesium, thought i would splash out on a carling 8 pin rocker from mobilecentre ltd.
Problem I have is how to wire the Carling.
The old switch had 5 pins, live in at the centre then an earth either side (earthed to chassis) then an output to each motor.
switch looks like this:
the Carling replacement looks like this:
Any help much appreciated.
Post #1023972 8th Feb 2024 1:52pm
BobC
I did find this diagram for the 8 pin switch. Dont know if I use 8, 7,3, 2, 1 or if I have to conect 1and 4, 2 and 5, 3 and 6.
Post #1023978 8th Feb 2024 2:34pm
geobloke
Not sure where I got this from now (thanks whomever it was) but I downloaded this a while back...
Post #1023981 8th Feb 2024 2:38pm
BobC
That one is in one of the how to guides at the bottom of the page on this link.
https://newwiremarine.com/wiring-diagrams/#
Post #1023994 8th Feb 2024 5:23pm
BobC
The diagram popped up by Geobloke is the right one. I've taken some pics of my instal and will upload later.
Bob
Post #1024094 9th Feb 2024 1:40pm
BobC
Ok, now the carling contura Ii rocker doesn't want to fit the existing blank hole. Guess I need to modify it, any suggestions?
Post #1024098 9th Feb 2024 2:21pm
BobC
Just have the positive from the dash light to connect to illuminate the switch with sidelights.
Needed to file the existing electric window td5 dash slots a smidge and these fitted. Will try and fit a purpose made housing to tidy it up a bit.
Post #1024202 10th Feb 2024 1:29pm
