![]() | Home > Technical > TD5 electric window kit, switch change to carling contura II |
BobC Member Since: 31 Aug 2023 Location: Cumbria Posts: 8 ![]() ![]() ![]() |
I did find this diagram for the 8 pin switch. Dont know if I use 8, 7,3, 2, 1 or if I have to conect 1and 4, 2 and 5, 3 and 6.
Not sure where I got this from now (thanks whomever it was) but I downloaded this a while back...
![]() ![]() Click image to enlarge |
That one is in one of the how to guides at the bottom of the page on this link.
https://newwiremarine.com/wiring-diagrams/# |
The diagram popped up by Geobloke is the right one. I've taken some pics of my instal and will upload later.
Cheers Bob |
Ok, now the carling contura Ii rocker doesn't want to fit the existing blank hole. Guess I need to modify it, any suggestions?
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Just have the positive from the dash light to connect to illuminate the switch with sidelights. Needed to file the existing electric window td5 dash slots a smidge and these fitted. Will try and fit a purpose made housing to tidy it up a bit. |
