Home > Puma (Tdci) > Strange alarm fault |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5707 |
Possibly water on one of the switches or dodgy bonnet switch?
9th Feb 2024 4:04pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
If you have a suitable diagnostic tool you can interrogate the alarm ECU and see what triggered it. Saves a lot of time.
9th Feb 2024 4:54pm |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 193 |
Any recommendations?
My basic OBDII scanner isn't really cutting it at the moment and I need to upgrade, something that can put Electronic Parking Brakes in Maintenance Mode would be a great help. Craig. โDon't believe everything you read on the internet.โ โ Abraham Lincoln www.scotgrc.co.uk |
9th Feb 2024 5:34pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
Itโs common for them to play up, they are relatively cheap to replace which is why I have any suspicions I just replace them.
The bonnet item is not as cheap though. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
9th Feb 2024 8:55pm |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 |
Alas, the issue has reappeared.
The rubber sleeve on the bonnet switch is perished and the plunger is wonky. Ordered a replacement (AMR2022) from John Craddocks eBay store ยฃ15 delivered (vs ยฃ46 if bought direct through their website). Hopefully this sorts the issue. 2011 CSW XS 90 |
2nd Apr 2024 8:58am |
