Home > Off Topic > Makita Angle Grinder - DGA517Z |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 |
My old corded angle grinder finally had to be retired from fine work duties at the weekend. I am tiling and the bearings must have gone as it was chipping the tiles like no bodies business; used a couple of different diamond discs to be sure.
As I'm saving ~£500 doing the job myself, so decided to buy a decent brushless grinder and opted for this: https://www.powertoolworld.co.uk/makita-dg...-body-only I have to say it is incredible. Even using the 115mm diamond discs it cuts like butter, with no chipping. I only have one 5ah battery and find that by the time I need to charge it, I'm ready for a break anyway. A lot of money, but another excellent product from Makita. 2011 CSW XS 90 |
2nd Feb 2024 9:36am |
pistonfields Member Since: 29 Mar 2022 Location: Zurich Posts: 72 |
Workshop buddy has one. Used it while refitting our sailboat a couple of times. Brilliant tool!
9th Feb 2024 10:11am |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 431 |
I do like most of the Makita cordless tools.
I do NOT like the way the Makita for changing disks. So dammed primitive.. The Germans did it so much better with the Metabo M Quick release. Once you are used to that.. no return ?si=LP6DP1r_D0vrTNHm Probably will fit on the Makita. No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
9th Feb 2024 12:45pm |
You need to work on your grip strength
On most grinders you can just press the button and then use the disc to unscrew the nut. Then replace the nut and tighten by hand; works that way on the makita and my old bosch. 2011 CSW XS 90 |
9th Feb 2024 12:59pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5732 |
I’ve got the quick nut on my Makita grinders |
9th Feb 2024 4:07pm |
Outlaw1 Member Since: 11 Aug 2016 Location: east sussex Posts: 268 |
you can buy a quick release for all 115mm grinders i think
9th Feb 2024 6:14pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1629 |
Grinder discs should only be on hand tight, I’ve never tightened one with a spanner in my life!
10th Feb 2024 6:42pm |
