Home > Off Topic > Makita Angle Grinder - DGA517Z
SJM2018
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Aintree Green
My old corded angle grinder finally had to be retired from fine work duties at the weekend. I am tiling and the bearings must have gone as it was chipping the tiles like no bodies business; used a couple of different diamond discs to be sure.
As I'm saving ~£500 doing the job myself, so decided to buy a decent brushless grinder and opted for this:
https://www.powertoolworld.co.uk/makita-dg...-body-only
I have to say it is incredible. Even using the 115mm diamond discs it cuts like butter, with no chipping.
I only have one 5ah battery and find that by the time I need to charge it, I'm ready for a break anyway.
A lot of money, but another excellent product from Makita. 2011 CSW XS 90
Post #1023292 2nd Feb 2024 9:36am
landy andy
It’s worth giving it a good regular clean with an airline after tile cutting 👍🏻👍🏻
I don’t know what blade you are using but there are special tile cutting blades for battery grinders and these work even better than standard blades.
Post #1023298 2nd Feb 2024 10:16am
pistonfields
Switzerland
Workshop buddy has one. Used it while refitting our sailboat a couple of times. Brilliant tool!
Post #1024067 9th Feb 2024 10:11am
Defendit..
Netherlands
I do like most of the Makita cordless tools.
I do NOT like the way the Makita for changing disks. So dammed primitive..
The Germans did it so much better with the Metabo M Quick release. Once you are used to that.. no return
?si=LP6DP1r_D0vrTNHm
Probably will fit on the Makita. No Mud flaps for my 90.!
P300 S MY21 on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1024085 9th Feb 2024 12:45pm
SJM2018
You need to work on your grip strength Laughing
On most grinders you can just press the button and then use the disc to unscrew the nut. Then replace the nut and tighten by hand; works that way on the makita and my old bosch. 2011 CSW XS 90
Post #1024090 9th Feb 2024 12:59pm
landy andy
I’ve got the quick nut on my Makita grinders Thumbs Up Thumbs Up
Post #1024111 9th Feb 2024 4:07pm
Outlaw1
England 2010 Defender 110 Puma 2.4 USW Santorini Black
you can buy a quick release for all 115mm grinders i think
Post #1024124 9th Feb 2024 6:14pm
NickMc
Grinder discs should only be on hand tight, I’ve never tightened one with a spanner in my life!
Post #1024245 10th Feb 2024 6:42pm
