Home > Td5 > Td5 rear axle breather
Page 2 of 2 <12
Register
Thanks for the advice. I get a genuine warm feeling when I can infer it’s fine for a bit.
All good removing the breather so no internal pressure, just need to park up with a lean to OSR corner and I’ll have the facts.
Otherwise it’s a search for parts on the way from Granada to Algeciras, or whatever Morocco has to offer. Everything's a hammer.
Post #1023110 31st Jan 2024 3:06pm
geobloke
At the very least look to get the seals and lock nuts DHL'd out to you. Defo get them overnighted as spares. Did you pack a hub nut socket?
For reference it is a 52mm socket. IIRC a number of tractors use the same size so if you have not got one you should be able to find one in Spain.
Post #1023201 1st Feb 2024 11:28am
Register
Just as was relaxing into an occasional top up of gear oil, you've now rattled me.
Almost enough tools for a rebuild but certainly not a 52mm spanner. Everything's a hammer.
Post #1023262 1st Feb 2024 8:22pm
geobloke
Do not worry too much and sorry I didn’t mean to rattle you. I am positive you will be able to find a 52mm socket or box spanner out in Spain. I suspect there might even be a Def2 forum member out there with one you can borrow. Worth asking…
Post #1023275 1st Feb 2024 10:05pm
landy andy
Don’t rebuild whilst away. If you are desperate to do something, which it doesn’t seem you are, get a new cap for the end of the shaft / drive flange.
Post #1023281 2nd Feb 2024 5:19am
Register
Thanks both for input.
In truth I’m desperate to do nothing apart from top up fluid if necessary.
No issue sorting it when I get back, but right now it’s all a bit roadside. Everything's a hammer.
Post #1023293 2nd Feb 2024 9:50am
Santana uses/used the same hub arrangement so it is probably quite easy to find a 52mm box spanner (or the Santana special tool) in Spain if necessary.
Somewhere I have a note of the part number of the Santana tool, if I can find it I will post it here.
Update: found it, it is 161952.
Post #1023304 2nd Feb 2024 10:58am
Register
thanks for that.
A bit of local knowledge may prove to be a good thing.
Hopefully on the drive in London Very Happy Everything's a hammer.
Post #1023315 2nd Feb 2024 12:12pm
Register
Thanks all for your advice to date.
I’m still on the road with limited leakage overnight but otherwise all good.
Any thoughts on this (which comes highly recommended 😂) before I add some to the diff?
Thanks Everything's a hammer.
Post #1024813 15th Feb 2024 5:34pm
Page 2 of 2 <12
