![]() | Home > Td5 > Td5 rear axle breather |
At the very least look to get the seals and lock nuts DHL'd out to you. Defo get them overnighted as spares. Did you pack a hub nut socket?
For reference it is a 52mm socket. IIRC a number of tractors use the same size so if you have not got one you should be able to find one in Spain. |
Register Member Since: 11 Jun 2023 Location: London Posts: 82 ![]() ![]() |
Just as was relaxing into an occasional top up of gear oil, you've now rattled me.
Almost enough tools for a rebuild but certainly not a 52mm spanner. Everything's a hammer. |
Do not worry too much and sorry I didn’t mean to rattle you. I am positive you will be able to find a 52mm socket or box spanner out in Spain. I suspect there might even be a Def2 forum member out there with one you can borrow. Worth asking…
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5799 ![]() ![]() |
Don’t rebuild whilst away. If you are desperate to do something, which it doesn’t seem you are, get a new cap for the end of the shaft / drive flange.
Thanks both for input.
In truth I’m desperate to do nothing apart from top up fluid if necessary. No issue sorting it when I get back, but right now it’s all a bit roadside. Everything's a hammer. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17581 ![]() ![]() ![]() |
Santana uses/used the same hub arrangement so it is probably quite easy to find a 52mm box spanner (or the Santana special tool) in Spain if necessary.
Somewhere I have a note of the part number of the Santana tool, if I can find it I will post it here. Update: found it, it is 161952. Last edited by blackwolf on 2nd Feb 2024 12:18pm. Edited 2 times in total |
thanks for that.
A bit of local knowledge may prove to be a good thing. Hopefully on the drive in London ![]() |
Thanks all for your advice to date.
I’m still on the road with limited leakage overnight but otherwise all good. Any thoughts on this (which comes highly recommended 😂) before I add some to the diff? ![]() Click image to enlarge Thanks Everything's a hammer. |
