Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17527 |
Dealers are allowed 12 minutes total to fit both brackets, and an additional 12 minutes for "drive in/drive out" (there's a link to all the TSBs on the first post of this thread).
22nd Jan 2024 6:33pm |
Sawn Member Since: 22 Jan 2024 Location: Weymouth Posts: 3 |
Had this happen last week 😳
It's been nothing but hard work to get this to a local dealer due to how busy they are, to get it booked in for inspection, then the amount of questions about it's history 😔 Do you know when you get a bad feeling about something about to happen Click image to enlarge Click image to enlarge |
22nd Jan 2024 6:35pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 671 |
That was very lucky - I would definitely be notifying vehicle safety branch at the DVSA. vsb@dvsa.gov.uk
22nd Jan 2024 7:00pm |
Given that it is a known and acknowledged fault I hope that LR gives you a new axle free of charge.
I was dismayed earlier today to read on a motor industry website that it is estimated that there are presently 10,000 JLR vehicles awaiting spare parts which are unobtainable, and 5,000 JLR customers driving courtesy cars because of this. The reason nobody can now get a courtesy car is because there are none left. The typical wait for parts is 3 months, and some people have been waiting for 9 months for parts (the warranty will have expired before their vehicle is returned). Then there's the insurance problem. It's not all bad news though, at least customers can look forward to JLR's introduction of "wellbeing features". How much longer can JLR survive like this, I wonder. |
22nd Jan 2024 8:05pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3466 |
So this is a case that failed after approx 12 years. Guess fatigue will start doing its work on the defective axles. Just a matter of time. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
22nd Jan 2024 11:27pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4730 |
Mine is 2011 and had the brackets fitted years ago. I suppose I'll need to check underneath before I drive it. 1982 88" 2.25 diesel
23rd Jan 2024 12:18am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
Mine is also 2011, also bracket fitted, I just look for an oil leak on the floor where it is parked DEFENDER 90 TDCI XS,
23rd Jan 2024 6:11am |
pistonfields Member Since: 29 Mar 2022 Location: Zurich Posts: 76 |
Is there a sensible way of fixing it? e.g. re-welding it or welding some sort of plate over it? |
23rd Jan 2024 7:51am |
A new axle case would be the sensible way to fix it, although I suppose that there is no reason why it couldn't be removed, cleaned, welded properly, and reassembled. I'd also be replacing the halfshaft since it is probably carrying much of the weight of that corner of the vehicle and cannot be straight any more.
The problem is (I have been assured by someone in the know) an issue with the weld position, so the material thicknesses and specifications are the same for the sound and unsound axles. Ergo if you could re-weld the broken axle in a way which you knew to be sound you should be absolutely fine. I doubt that adequate weld prep for a good job could be done with the axle assembled and on the vehicle though. If I was taking this route I would get it done by a very competent welder (ideally a coded welder) and NDT'ed afterwards. The original recall notice (see the first post in this thread) states:
This suggests to me that JLR should replace Sawn's axle case without question however unfortunately experience with JLR suggests that it will put more cost and effort into avoiding doing anything at all than it would take to repair the vehicle. I will be interested to hear the outcome.
I know what you mean and agree with you, but isn't it strange the way our minds work? I'd be inclined to think that it is incredibly unlucky that the end has broken off the axle! If however the end is going to break off, to have it happen in such a benign and non-catastrophic was is very, very lucky indeed! |
23rd Jan 2024 10:06am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2442 |
IMO, the best way to go around this, would be to actually weld some well designed plates. Anyway, that is what I would definitely do if I had one of those cheese-MIG welded axle casings.
Maybe some of those metal parts for chassis providers can come up with some sort of DIY solution for those who prefer a branded part (or it might be the case they do not want to get involved in this obscure from LR). Puma 110" SW ............................................................. Earth first. Other planets later Last edited by MK on 23rd Jan 2024 12:29pm. Edited 1 time in total |
23rd Jan 2024 10:46am |
Mine has the brackets fitted; can't say when or where it has been done (it's an import vehicle from Italy; no idea if it was fitted in Italy or by the PO in Switzerland). But I'm in for a front and rear axle rebuild anyway (new diffs, new halfshafts, new everything), so it might be a sensible time to actually address the potentially welds.
23rd Jan 2024 11:27am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Sawn, thank you for posting photos. I guess it happened at low speed? Interesting to see the failure and hope you get a replacement on JLR! James
23rd Jan 2024 1:15pm |
As Blackwolf said in his first 4 words of his reply. Mind you, you do not necessarily need to have a Defender axle. There are a lot of 300tdi Discoveries with rotten boddies, but perfectly usable axle cases. Needs to be the 300 Discovery, as the earlier 200 Discoveries have narrower radius arms. This is the route that I had planned, and got an axle case just waiting to get replaced (I am replacing the panhard rod brackets as post 2002 got different panhard rod brackets on the axle, but that is optional - as you can re size the 14mm to 16mm holes for that panhard bolt), but honestly, since I got the brackets installed, I am much more happier to drive the Defender, without the need to worry too much. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
23rd Jan 2024 2:07pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1802 |
On a serious note I expect JLR to try and refuse warranty / liability on Sawns 110 as it appears to have non standard wheels / tyres or spacers fitted which they may claim will have altered the design stresses on the axle.......
Also the non standard headlamps, indicators and side lights may have affected the aerodynamic coefficient of the cooling jet wobble force and led to the unscheduled disassembly of the component..... Seeing the trouble one of the members has on here not being able to get the safety brackets fitted because the bolts are the 'wrong way round' I may not be far from the truth. After several of these types of post SWMBO now knows why I wouldn't buy a Disco Sport but bought a 'yota instead |
23rd Jan 2024 2:53pm |
