Home > Td5 > sunroof - with twist handle |
I suspect the main seal has not seated properly onto the roof panel. You might want to lift the seal and squeeze a little silicone underneath it to form a proper seal.
As for the glass seal, a smear of silicone grease is enough to seal and prevent the glass from freezing to the seal. It is also worth checking that the front sliding hinges are able to slide smoothly. These can rust and prevent the glass from sealing properly at the front. They are designed so the glass can be removed during the summer for the full open air experience. |
17th Jan 2024 7:55pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6113 |
Mine used to leak (twisty handle)
in the end I smeared the seal in vaseline, which stopped it leaking, then didn't open it for the next 4 years until I sold it. Job jobbed.... |
17th Jan 2024 8:13pm |
To be honest mine has never leaked, but it does form the most amazing forest of icicles in winter that are extremely cold when they fall off down between your neck and collar
17th Jan 2024 8:17pm |
