Home > Faults & Fixes (L663) > Sunroof rattle |
sullivan1337 Member Since: 24 Oct 2023 Location: Pittsburgh Posts: 8 |
I actually have this EXACT same issue right now.
It seems to be worse in dryer and colder temperatures, and if I put pressure on the back fixed sunroof glass the noise goes away. It's currently at the dealer, but so far I've been given the "normal noise from body flex" excuse.. Which is completely incorrect because the loaner Defender with the same pano roof hasn't made the noise in over a week we've had it. I've seen several options for tightening the anchor bolts down, or applying grease/lubricant to that area. I'll update you if we actually get any "real fix" from the dealer. 24MY Defender 110 P400 X-Dynamic SE, Pangea Green. |
7th Jan 2024 6:37pm |
jimjamken Member Since: 01 Mar 2023 Location: Surrey Posts: 84 |
Thanks Sullivan1337, good to know someone else has the same issue, although sorry you have the problem at all. Mine has gone into the dealership for an ongoing issue today and I've asked them to look at it as well. Let's see what the 'experts' say.....I'm sure they'll go with what you've experienced in terms of "normal noise from body flex" but I can't accept that from them.....I've never had fixed glass coming loose when the temp drops in other cars!
8th Jan 2024 10:08am |
Hi Sullivan1337, I heard back from the dealership and they've resolved the fixed pano glass rattle by re-sealing it (per JLR guidance). I don't have it back yet as they're having to raise a TA on another fault, but I'll let you know if that's fully sorted it when I do.
10th Jan 2024 3:01pm |
Manuto Member Since: 27 Jan 2021 Location: Vancouver Posts: 9 |
Hi jimjamken,
Did you get your car back and did the fix solve the actual issue? I have similar panoroof squeak noises... My dealer keeps lubricating the rubbers but only helps partially on the short-term. |
12th Jan 2024 3:34am |
Hi Manuto, I haven't had it back from the dealership yet as they're trying to resolve a fault with the alarm being triggered when it's on timed charge (p400e)....they've got a TA raised with Land Rover centrally to try and resolve it....third chance now! I'll let you know when I get it back.....
12th Jan 2024 8:12am |
I just got back the car yesterday, and can confirm that the noise is 99% gone!
And here are 2 videos I sent the dealer when I was able to capture the noise (2nd video is the best one I was able to capture): https://photos.app.goo.gl/pYevevXc1geZpKs8A They had to drop the headliner and tighten the "anchor bolts" (part numbers LR137048, LR137043, and LR132294) for the sunroof frame. Parts 2, 3, and 4 from this diagram: https://parts.landroverpalmbeach.com/a/Lan...45635.html Click image to enlarge 24MY Defender 110 P400 X-Dynamic SE, Pangea Green. |
12th Jan 2024 4:56pm |
Thank you for the update!
I am glad that it’s fixed… even at 99%. |
14th Jan 2024 11:17pm |
