Home > General & Technical (L663) > Defender P400 4WD vs Discovery 5
nebc100
Luxembourg
Hello all,
Please forgive me, but I am in the position where I currently have a 2017 D5, and have just bought a Def110 P400.
I love both vehicles as they suite my needs really well (towing and getting in & out of horse field even in the winter).
I have, however managed to cause the Defender to skid a few time when pulling away from a junction, and have NEVER done this in the Disco.
I have GoodYear Duratracs on the Discover, and have the standard road tires on the Def.
Is this the cause, or are there differences in the 4WD system between the two vehicles?
I thought that they were basically based on the same system.
My Disco has the hi/low transfer case and ediff, sadly my Def doesn’t have the ediff!
Any thoughts would be appreciated!!
Post #1019310 26th Dec 2023 6:05pm
Chicken Drumstick
What engine in the Discovery?
Post #1019314 26th Dec 2023 6:42pm
nebc100
Luxembourg
My disco is a Tdv6
Why?
Post #1019318 26th Dec 2023 7:36pm
Chicken Drumstick
I would think the power and power delivery of the engine would play a bigger part of "managed to cause the Defender to skid a few time when pulling away from a junction" than the stock tyres or 4wd system.
TDV6 is sluggish off the line and probably limits torque, it also makes almost 150hp less and is 2 seconds slower to 60mph.
Maybe just be more gentle with the throttle pedal in the more powerful Defender. Very Happy
Post #1019323 26th Dec 2023 9:04pm
Chicken Drumstick
BTW - the new Defender and Discovery 5 are built on the same platform and share most major parts bar the bodywork and interior trim. The 4wd systems are the same.
Post #1019324 26th Dec 2023 9:05pm
Moo
Ukraine
Interesting, I didn't know that. Thumbs Up Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1019325 26th Dec 2023 9:42pm
markb110
When the D4 had the problem of snapping crankshafts JLR did the amazing 'fix' of introducing a software update to reduce power during pull aways from a standing start.
Did they do the same with the Ingenuim engine?
Post #1019336 26th Dec 2023 10:59pm
Moo
Ukraine
Don’t notice any lag on the Ingenium engine pulling away. If there was a software update not sure it worked though. Eiger Grey MY23 D250 SE with bits. Known as Noddy.
Post #1019339 27th Dec 2023 12:40am
nebc100
Luxembourg
Chicken… that is what I thought, and why I was asking here if there were any differences that I wasn’t aware of.
Honestly, not sure it is down to the engine… the tdv6 has more torque than the P400 and it is torque that helps from standstill.
Maybe you are right though…. I will know when I put some AT tires on it next year!!
Post #1019343 27th Dec 2023 9:33am
nebc100
Luxembourg
Markb110… where did you hear about this “software update” to reduce the toque from standstill?
I have been a member of the D3 drum for years (having has D3 and RRS) and have never heard any mention of this.
Post #1019344 27th Dec 2023 9:34am
Retroanaconda
If you’ve got an open diff it’s going to be much easier to slip a wheel.
The diff will normally lock up when accelerating exactly for this reason, and as noted the driveline systems are very similar.
Post #1019346 27th Dec 2023 10:21am
Chicken Drumstick
Torque is 442ft-bl vs 406ft-lb. Close enough to not be hugely different. But the petrol is still a lot more powerful and will rip through the rev range faster. Chances are you are probably not at 2000rpm when any slip happens. As it is difficult with an automatic to use large throttle inputs at low rpm, as the gearbox will downshift to keep you in the sweet spot torque wise.
Post #1019354 27th Dec 2023 11:16am
lightning
l've had something similar in my new Defender D250
l had to cross a muddy field and progress seemed slow, almost as if the wheels were spinning, in fact it almost got stuck.
This was not in keeping with the reviews which showed the vehicle making light work of similar conditions.
The transmission was in default "Comfort" mode so l changed it to "grass gravel snow"
immediately the Defender started to pick up speed and had no further problems crossing the field.
l wonder if in the default "Comfort" mode the 4wd system is less active?
Post #1019361 27th Dec 2023 1:49pm
XplusYplusZ
My d250 will squeal a tyre from standstill if i've got plenty of lock on and a heavy right foot (AT tyres). Not full on drifts, just a squeal (and a chuckle).
Post #1019532 29th Dec 2023 1:39pm
