Home > Maintenance & Modifications > Washer jet repair kit - how do you do it
chopcat
Wales 2000 Defender 90 Td5 CSW Java Black
I have had a search see references to the 2 part washer repair kit , which I have now got but I have no idea how to do it.
There is a barbed bit and then the washer head.
If I was a betting man my money would be on shove the barbed bit into the bit sticking out of the car and then push the washer head over it. But it looks like it might be a one try option with no ability to take it apart so some guidance would be appreciated
Trevor
Post #1018283 13th Dec 2023 5:53pm
chopcat
I see from the simply fab life video they tap on the replacement head but not sure if that means the barbed bit is surplus to requirements
T
Post #1018286 13th Dec 2023 6:20pm
landy andy
I fitted a LR original repair to mine last week. And broke the new bit. So I’m not the person to ask Embarassed Embarassed
Post #1018289 13th Dec 2023 6:29pm
chopcat
This is the bit i am talking about
Post #1018340 14th Dec 2023 9:36am
geobloke
Those washer jets are horrid horrid things even when in complete form. I am all for repairing things, but these things... Rolling Eyes
I highly recommend you save your time and effort and either fit a replacement or an upgraded metal version of the washer jets.
Post #1018351 14th Dec 2023 10:27am
ChrisDefender
Rolling with laughter
I also have a replacement original part for this, as I snapped a pin in one of my jet holes and its never been quite as good. It does give a decent spray up the window but I have to clean it every few months.
As the original post above, I'd also like to know if I can pull off the old and simply push on the new outer part with no problem, as I cannot face it going wrong and having to take the dash apart to fix it.
I appreciate the billet parts are a vast improvement, but with a long list of 'things' that is way down on the list!
Post #1018368 14th Dec 2023 11:34am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Pull old out a push back the new? Old made from hard plastics, hardened and brittle because of the age. I think, it will just broke, and you will need to remove the dash anyway. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1018380 14th Dec 2023 12:52pm
chopcat
Not according to this video
?si=hoU_oQ5OdWdLTAym
Post #1018382 14th Dec 2023 1:18pm
landy andy
T
Yes the barbed bit is surplus to requirements, it is a hose joiner, and I don’t know why it is included to be honest. You just smack the new on to the old base. Thumbs Up
Post #1018383 14th Dec 2023 1:22pm
chopcat
I will report on progress tomorrow.
Ta
Trevor
Post #1018407 14th Dec 2023 5:57pm
piechipsandpeas
Australia 2013 Defender 110 Puma 2.2 SW Indus Silver
Be careful to have it aligned properly before knocking it on, and be careful which part you "smack" as it is quite brittle plastic.
Post #1018438 15th Dec 2023 11:44am
landy andy
I agree with above Twisted Evil Twisted Evil
Post #1018453 15th Dec 2023 4:17pm
ChrisDefender
Chopcat, did you manage to replace the jets with the original plastic part OK?
Post #1022391 24th Jan 2024 3:57pm
As mentioned, handle it with care as they are brittle even when new.
I seem to renter taking centre dash out, then the HU rear bracket and then that allows easy access.
You can do it from the side I think as well, don’t over tighten it either. Chillin In The Backwoods🇬🇧🇺🇸
Post #1022392 24th Jan 2024 4:06pm
