Home > Puma (Tdci) > Crunching Noise And Traction Control Light Flashes
Page 2 of 2 <12
Laurie
Another possibility is the diff-lock is stuck in engaged.
Post #543842 27th Jun 2016 11:15am
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
" ... And where exactly would the equivalent earth be on a tdci? ... "
I don't know to be honest, I don't have a wiring diagram for the ddci, I was just offering a possible cause and suggesting that sometimes, serious sounding faults can often have a simple cause and remedy.
Post #543878 27th Jun 2016 2:08pm
schuee
No joy yet, not had any time to have a closer look into it, I'm convinced like others have mentioned it's something to do with something worn, as I know there is some backlash in the transission which LR say is within accpectable tolerances, also read stories of the infamous intermediate transfer shaft giving up the ghost, though don't want to find out the hard way as others have, I'm currently under extended warranty with LR so will point out my worries to them again down at the dealers and to fair to them they have been excellent over the years, it has done it quite a few times in the last week, always from standing still then pulling away which you can feel the slack take up somewhere then the crunch and TC light, then is all fine.
Post #543919 27th Jun 2016 4:26pm
schuee
SimonDavies wrote:
Intermediate shaft splines worn?
When I would select 1st and pull off I would have a grinding noise. I would only have the same noise when I selected reverse and spun the shaft the other way. As time went on, this got much worse where any forward gear after a change would grind and you would feel it. Eventually it went completely - no drive.
Just something to think about.
Hello Simon,
Eventually when yours went completely, and you lost drive what was the problem, and resolution ?
Thanks
Post #544171 28th Jun 2016 12:36pm
AWOL
I had this a few times, same situation but very intermittent, over course of last few months.
Intermediate shaft gave up a few days ago... if you've not had the shaft checked then I'd recommend doing so.
Post #606851 5th Mar 2017 9:26am
M7even
United Arab Emirates 2014 Defender 90 Puma 2.2 LXV Hard Top Santorini Black
Hello,
Reviving this old post but this morning I had the exact same problem, Whenever I'd pull away from second gear or first it happens, Took it to a LR specialist and he hooked up a OBD2 scanner and just to look at the live data from the speed sensors of all four wheels, 3 of them showed the same speed from pulling away except one which was stuck on 1, he just tapped the speed sensor a bit and it got fixed!
Now when pulling away there isn't any noise and no flashes, hope this helps anyone who has the same problem. 2014 Defender LXV
2023 Defender 90 HSE
Post #968640 22nd Oct 2022 12:19pm
nick.bw
United Kingdom 2014 Defender 110 Puma 2.4 XS CSW Santorini Black
This is the best exact same issues I have.
Any idea on what the fix is?
Post #1017158 2nd Dec 2023 4:48pm
M7even
Mentioned it above, turned out to be a speed sensor on one of the wheels.
just tapped it and it got fixed. 2014 Defender LXV
Post #1017159 2nd Dec 2023 4:49pm
nick.bw
Do you know where he speed sensor is located?
Thanks for the reply
Post #1017160 2nd Dec 2023 4:54pm
In the top swivel pin.
Post #1017193 2nd Dec 2023 8:37pm
jst
Also check the sensor connections to loom. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1017198 2nd Dec 2023 9:59pm
nick.bw
Thanks all
Little spanner and tapped both sensors and no more traction control issues.
It's bloody mucky down there. What's best to clean around the swivel pin?
Post #1017316 3rd Dec 2023 8:18pm
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Now that you have resolved it for the moment, it’s with checking to make sure the end of the front half shafts/cvs are shimmed correctly, if they are too sloppy you’ll find the issue will return.
Chris
Post #1017465 4th Dec 2023 11:16pm
nick.bw
Cheers for the suggestion
Post #1017476 5th Dec 2023 8:11am
Page 2 of 2 <12
