![]() | Home > Faults & Fixes (L663) > Failed Signature DRL fix |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3060 ![]() ![]() |
Well, that's fabulous news because these light units are nearly £3,000 each and once out of warranty you are on your own.
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1469 ![]() ![]() |
![]() That’s just bonkers. Once the thieving parts scumbags realise the cost of these things then expect to see a rise in thefts ![]() |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3460 ![]() ![]() |
Yes, had both replaced under warranty on my Velar as they were cracking, it was a battle. £2.5k + VAT per corner. The rears cracked as well, though there was a technical bulletin for the rears 24MY 90 D250 HSE, Tasman Blue
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1443 ![]() ![]() ![]() |
The chip he is talking about has been available for quite some time now, you can get them from China for about £15, as usual it's not something he has discovered, he is just copying what other people do and then will charge a premium for it
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 925 ![]() ![]() ![]() |
£3000 each!……
![]() Land Rover really have alienated their old school supporters….☹️ Jim |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6662 ![]() ![]() ![]() |
Classic Defender headlights, £20+VAT each. Progress
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3707 ![]() ![]() ![]() |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2731 ![]() ![]() |
The standard base spec lights are much cheaper luckily.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1235 ![]() ![]() ![]() |
I am getting old I suppose, but when I shop for a second hand car, I do research on what fancy stuff to avoid because when it breaks it's typically expensive to fix.
So when I am ready to buy my pretender I will be looking for the base spec. |
There's often ways around replacing these expensive parts, as above. lf it's a common failure there's likely to be an aftermarket alternative or a repair possible, as the vehicle gets older and aftermarket companies start looking at ways to make money from it.
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 167 ![]() ![]() |
That's what I did buying it from new and was pleased, much later, when I discovered how much the fancy ones cost to replace. ![]() Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
