Home > Maintenance & Modifications > Engine cleaning
SJM
Engine cleaning
Had to put my Defender in the dealer last week to have a few minor bits fixed - mainly just loose rubber seals round doors that were causing a leak in passenger footwell. The dealer fixed it all no probs, but comented that the "engine is covered in mud". This may be something to do with some serious fun in the last few weeks, and it's true that the engine is filthy. I asked the dealer if they could arrange for it to be steam cleaned etc (at my expense) and they said they don't do it because of risk of damage etc. Fair enough, but how elese can I get it clean? It's filthy, so I really want it done. I haven't got the time unfortunately to spend a day underneath cleaning each part, so thought a steam clean would be ok - am I wrong? Anyone got any recommendations please - I'm based in Kent/ South London if anyone knows of local-ish companies.
Thanks in advance.
Simon Simon
'11 Defender 110XS Utility SW
'07 Discovery 3 HSE
'58 Porsche 356A (not good off road)
'59 Lambretta (not good on or off road!)
Post #101352 21st Nov 2011 2:15pm
Lorryman100
The probable reason for the dealers refusing to do it because of possible damage, not to the engine itself but rather all the electrical plugs and connections contained in the engine bay. I personally think you would be opening a big can of future electrical problem whoopass in getting this done. Just my opinion though, Whistle
Brian.
Post #101409 21st Nov 2011 6:56pm
markb110
No idea how that could have happened Simon Whistle
Pm sent with what i do
Thumbs Up
Have fun
Mark
Post #101420 21st Nov 2011 7:16pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Find clean water to drive through to reverse the process. Rolling with laughter Puma 110 SW
90 V8 SOFT TOP
Post #101428 21st Nov 2011 7:32pm
Once the salisbury silt is in there, you need hot water/steam to get it out. I had my td5 steamed a couple of times, just get someone who knows about land rovers to do it and not an ape.
I can recommend an indy in Wiltshire but not sure about your neck of the woods.
steve
Post #101446 21st Nov 2011 8:25pm
mermoto
High pressure WD40 Mr. Green
Post #101505 22nd Nov 2011 1:44am
SJM
Laughing Laughing Er, yes, well that may have contributed as well.... Embarassed
Thanks for the tips all, and the PM Mark. My personal favourite is the idea of a big clean water splash! Otherwise it looks like I'll have to find some time this weekend... Wink Simon
'07 Discovery 3 HSE
Post #101612 22nd Nov 2011 1:42pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Bilt Hamber Surfex HD - water based degreaser, brush on where you can get to, spray where you can't, use ordinary hose not power washer, use common sense near electrical connections, start engine afterwards and go for drive for ten mins, it'll be fine
Post #101697 22nd Nov 2011 6:26pm
Merlin
Hi markb110,
Your entry is too fast, but I expect you've been told that before.
Merlin
Very Happy
Post #101703 22nd Nov 2011 7:09pm
markb110
Hi Merlin
Cheeky sod Laughing
That's not me, that's my picture of Simon when he may or may not have contributed to the dealers dirty engine comment.
I won't show the picture of the other water hole that lead to water into the second row foot well - guess that's why the seals were being replaced Whistle
Mark
Post #101712 22nd Nov 2011 7:32pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
after the dealership started listing OFF-ROADING as an issue I started jet washing the engine bay, its been done half a dozen times now and with 54K on the clock and all seems ok, the only issue is the EGR not some thing that a jet wash will affect.
just my 2p's worth.
wait there did I say that the dealership once emptied water out of my water proof ECU Shocked
second thoughts ignore the scouser
Laughing
Post #101799 23rd Nov 2011 12:20am
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
Are the dealership saying its not fit for purpose, i,e cant go off road and the clean afterwards
Post #101825 23rd Nov 2011 9:43am
SJM
markb110 wrote:
Hi Merlin
Mark
The seals were being replaced as they were all coming away from the top of the door frames - same as happened on my Def 90 as well, so luckily this one was not related to that! Laughing To be fair to the dealer they were absolutely fine about it going off road, in fact their actual words were, "it's no problem going off road, that's what they're for...." - I found that quite refreshing! That's in stark contrast to a Porsche dealer I know who told a mate of mine that if he takes his 911 on a track then he'll invalidate the warranty Shocked Simon
'07 Discovery 3 HSE
Post #101829 23rd Nov 2011 10:34am
jst
just steam clean it. i steam clean any of my vehicle engines post an off road trip. the D4s, Puma and RRV engines are all jet washed at work too after wading. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #101995 23rd Nov 2011 5:53pm
SJM
Thanks for that James - I've ordered some cleaning/ water displacement products now so will have a go with those first. I may do a 'gentle' wash with the pressure washer first. I presume you just cover any major electrical components first? Simon
'07 Discovery 3 HSE
Post #102150 24th Nov 2011 9:18am
