![]() | Home > Maintenance & Modifications > Engine cleaning |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
The probable reason for the dealers refusing to do it because of possible damage, not to the engine itself but rather all the electrical plugs and connections contained in the engine bay. I personally think you would be opening a big can of future electrical problem whoopass in getting this done. Just my opinion though,
![]() Brian. |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2655 ![]() ![]() ![]() |
No idea how that could have happened Simon
![]() ![]() Click image to enlarge Pm sent with what i do ![]() Have fun Mark |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
Find clean water to drive through to reverse the process.
![]() 90 V8 SOFT TOP |
Once the salisbury silt is in there, you need hot water/steam to get it out. I had my td5 steamed a couple of times, just get someone who knows about land rovers to do it and not an ape.
I can recommend an indy in Wiltshire but not sure about your neck of the woods. steve |
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 ![]() |
High pressure WD40
SJM Member Since: 09 Dec 2007 Location: Kent Posts: 237 ![]() ![]() |
![]() ![]() ![]() Thanks for the tips all, and the PM Mark. My personal favourite is the idea of a big clean water splash! Otherwise it looks like I'll have to find some time this weekend... ![]() '11 Defender 110XS Utility SW '07 Discovery 3 HSE '58 Porsche 356A (not good off road) '59 Lambretta (not good on or off road!) |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
Bilt Hamber Surfex HD - water based degreaser, brush on where you can get to, spray where you can't, use ordinary hose not power washer, use common sense near electrical connections, start engine afterwards and go for drive for ten mins, it'll be fine
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 981 ![]() ![]() |
Hi markb110,
Your entry is too fast, but I expect you've been told that before. Merlin ![]() |
Hi Merlin
Cheeky sod ![]() That's not me, that's my picture of Simon when he may or may not have contributed to the dealers dirty engine comment. I won't show the picture of the other water hole that lead to water into the second row foot well - guess that's why the seals were being replaced ![]() Mark |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
after the dealership started listing OFF-ROADING as an issue I started jet washing the engine bay, its been done half a dozen times now and with 54K on the clock and all seems ok, the only issue is the EGR not some thing that a jet wash will affect.
just my 2p's worth. wait there did I say that the dealership once emptied water out of my water proof ECU ![]() second thoughts ignore the scouser ![]() |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
Are the dealership saying its not fit for purpose, i,e cant go off road and the clean afterwards
The seals were being replaced as they were all coming away from the top of the door frames - same as happened on my Def 90 as well, so luckily this one was not related to that! ![]() ![]() '11 Defender 110XS Utility SW '07 Discovery 3 HSE '58 Porsche 356A (not good off road) '59 Lambretta (not good on or off road!) |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8165 ![]() ![]() ![]() |
just steam clean it. i steam clean any of my vehicle engines post an off road trip. the D4s, Puma and RRV engines are all jet washed at work too after wading. Cheers
Thanks for that James - I've ordered some cleaning/ water displacement products now so will have a go with those first. I may do a 'gentle' wash with the pressure washer first. I presume you just cover any major electrical components first? Simon
