Home > Td5 > TD5 Clutch Pedal Mod
Page 2 of 11 <123 ... 91011>
Anderzander
I did this too. I felt it was a great improvement. I may have some pictures too somewhere.
The parts didn't come to 45 I'm sure - the only bit that seemed expensive was the silly plastic bush!
Post #71094 16th May 2011 1:23am
I'm suprised that you Td5 people actually need to fit these springs... my (factory) 300Tdi from 1996 had one as standard, and then my Td5 110 (2001) also had it.
Pretty much every other clutch pedal box (Td5 era) i've seen for same has had one fitted.
unless there was a batch that never did? Question Question
Post #71104 16th May 2011 8:01am
Anderzander
We're talking about Land Rover here Smile. Nothing should surprise us !
Post #71108 16th May 2011 9:21am
True... probably a pallet load of mid 80's pedals they had to use up Laughing Laughing
Post #71147 16th May 2011 3:37pm
Paul_1978
England 2004 Defender 90 Td5 CSW Zermatt Silver
Ive had a good look at my pedal and its not got the mod.
You must have followed some good owners.
Post #71175 16th May 2011 5:54pm
Paul_1978
I did the clutch pedal mod yesterday, bit of a fiddley buggar to do, but christ, what an improvement!
Well worth doing, makes the action alot lighter.
I had to undo the bolt securing the pedal to the master cylinder to get the spring in place, not a hard job just very fiddley, took me around an hour.
The parts were 45 from Britpart, the little U shaped plastic bush was 19, what a rip off!
Post #74282 5th Jun 2011 7:42am
Matt
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
Thumbs Up
Post #74325 5th Jun 2011 5:51pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Ive fitted this mod what a diference didnt do it like the mag (taking the bonnet off etc) just fitted it from the drivers footwell and used a pair of sniped nosed mole grips the fit the spring took 10 min
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #74847 8th Jun 2011 5:56pm
elpeede
The pedal in my 1990 110 (not a td5 but TD) is also stiff. Is this article specific to the TD5 only. I note the picture on the first page covers from 1986.
Post #74974 9th Jun 2011 12:37pm
Paul_1978
If you look at the drawing i posted on the other page, you are looking for a u shaped cut out on the pedal stem and a bracket behind this with two hols on either side to place the bushes on, if you have these i guess its a goer.
Doubt any major mods have been done on these parts.
Post #75167 10th Jun 2011 9:28am
CFB
I'm going to do this mod. Has anyone got the part numbers and details for the accelarator pedal mod too as I find this also has a lot of resistance. Andy
Post #84036 12th Aug 2011 12:14pm
landy andy
There are no parts required for throttle pedal mod. It is just a case of drill hole, and relocating spring into it.
Andy
Post #84158 13th Aug 2011 8:13am
CFB
Thanks, think I need to order the back issue of LRO, unless any kind sould woul be able to scan and mail it to me? (the instruction page that is) Andy
Post #84162 13th Aug 2011 8:57am
I did the modification to the clutch pedal on my 110 today, although it wasn't the easy but fiddly task that some have found. No amount of pushing, twisting, forcing and cursing could get the new spring into place. In the end, I resorted to disconnecting the clutch pedal from the master cylinder, after which it popped into place quite easily. Disconnecting the pedal took minutes and if I'd done that from the outset, I'd have saved myself a lot of time and frustration Rolling Eyes
Still, done now and the difference is incredible. It's much more driveable, particularly in traffic, and saves my old knee from a lot of grief Very Happy Darren
Post #91221 25th Sep 2011 3:51pm
John110
Ireland 2007 Defender 110 Puma 2.4 HT Stornoway Grey
Just ordered the parts there now, God I only found this website the otherday and many of the niggly little things that annoy me in my defender-the cures are posted here Very Happy
Thanks for this thread as the extremely heavy clutch on my current TD5 drives herself mad on a long journey Wink
John For those who understand, no explanation is needed...
For those who do not understand, no explanation is possible
Post #101495 22nd Nov 2011 12:23am
