Home > V8 > 1988 90 v8 3.5 - Throttle Pedal |
Is the throttle cable just slack on the throttle lever? Sounds like there is too much slack in the system. On the old 200tdi's you used to be able to adjust the cable slack to accommodate cables that stretch after a while.
9th Nov 2023 9:28pm |
mediamab Member Since: 01 Dec 2021 Location: Matlock Posts: 58 |
Gutt says that could be case yes as I assume throttle should impact the throttle well before the amount of movement I have to put on the pedal. Not sure how I solve that though?
9th Nov 2023 10:17pm |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 487 |
Just adjust the outer cable at the carb end.
10th Nov 2023 12:04pm |
Define adjust?
10th Nov 2023 12:05pm |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 902 |
If you’ve got a second pair of eyes, have a look at the carb linkage while someone else depresses the pedal. You’ll see how much free play is in the cable instantly. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
10th Nov 2023 4:30pm |
Ah ok yes can do that. How do I reduce the slack though?
Thank you! |
10th Nov 2023 5:06pm |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3437 |
On the diesels, you would just rotate that encircled part, keeping the rest of the cable steady. It will adjust the position of the outer cable relative to the in er cable, thus taking away any slack.
Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
10th Nov 2023 5:15pm |
Ah ok assume should be similar ey so I’ll take a look at the weekend! Slowly learning the v8!
10th Nov 2023 6:43pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 |
Great purchase! Does it have it's own thread? Would love to see some photos. James
11th Nov 2023 10:34am |
I will be starting one! Luckily already had the galv chassis and engine rebuild 8k miles ago. But going to try and take it back to how it was originally slowly but surely!
11th Nov 2023 1:41pm |
