Home > Maintenance & Modifications > td5 manifold |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1115 |
what is the best fix for the td5 manifold warp before it happens
21st Nov 2011 6:05pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
Have a spare for when it does?
21st Nov 2011 6:14pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
Remove the webs between the ports , it allows it to flex more.
21st Nov 2011 6:16pm |
any photos
21st Nov 2011 6:25pm |
Steve B Member Since: 22 May 2009 Location: Warwickshire Posts: 586 |
This Also open out the holes to 10mm except the center 2. I also made spacers to allow me to fit longer high tensile bolts, these will stretch and maintain the clamp load. IRB Developments will do you a skimmed/blasted and opened out manifold. This is where I got mine from. As mentioned some people remove the webs but I didn't. Steve |
21st Nov 2011 6:53pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3708 |
Replace the 8mm manifold to head bolts with 10mm 130's have feeling's as well you know
21st Nov 2011 7:12pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 559 |
when mine warped i got a ceramic coated one from td5 alive and a set of JE engineering studs and spacers but i noticed the gasket was blowing 11months later,so i took it off and found the manifold was warped again, so i sent it of to the local machine shop and had it skimmed (my guess is the ceramic one was a good one that hadent warped when it was coated) and upto press there is no signs of any blowing
For normal use id say have the manifold skimmed and fit a JE stud kit open the holes to 10 mm (except the middle 2) then it should be ok Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
22nd Nov 2011 9:49pm |
abomb1969 Member Since: 23 Jul 2011 Location: Welwyn, Hertfordshire Posts: 79 |
Can I ask what to look for, gasses blowing?
22nd Nov 2011 11:04pm |
Signs of soot is the main visual.
23rd Nov 2011 9:50am |
The first sign is usually a squeaking or whistling noise, which is the gases escaping under pressure. Darren
23rd Nov 2011 10:50am |
