Home > Maintenance & Modifications > td5 manifold
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
td5 manifold
what is the best fix for the td5 manifold warp before it happens
Post #101414 21st Nov 2011 6:05pm
T1G UP
Have a spare for when it does?
Post #101418 21st Nov 2011 6:14pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Remove the webs between the ports , it allows it to flex more.
Post #101419 21st Nov 2011 6:16pm
tolley
warp
any photos
Post #101424 21st Nov 2011 6:25pm
BigRuss
Best would be to have it machined flat once it's warped and re install it, that way the manifold won't warp again.
A new one will just warp Thumbs Up Russell
2011MY 110 XS USW Black
Post #101433 21st Nov 2011 6:42pm
Steve B
United Kingdom 2000 Defender 90 Td5 SW Caledonian Blue
This Thumbs Up
Also open out the holes to 10mm except the center 2. I also made spacers to allow me to fit longer high tensile bolts, these will stretch and maintain the clamp load.
IRB Developments will do you a skimmed/blasted and opened out manifold. This is where I got mine from. As mentioned some people remove the webs but I didn't.
Steve
Post #101437 21st Nov 2011 6:53pm
AndrewS
Replace the 8mm manifold to head bolts with 10mm 130's have feeling's as well you know Smile
Post #101443 21st Nov 2011 7:12pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
when mine warped i got a ceramic coated one from td5 alive and a set of JE engineering studs and spacers but i noticed the gasket was blowing 11months later,so i took it off and found the manifold was warped again, so i sent it of to the local machine shop and had it skimmed (my guess is the ceramic one was a good one that hadent warped when it was coated) and upto press there is no signs of any blowing
For normal use id say have the manifold skimmed and fit a JE stud kit open the holes to 10 mm (except the middle 2) then it should be ok
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #101770 22nd Nov 2011 9:49pm
abomb1969
United Kingdom 1998 Defender 110 Td5 CSW Santorini Black
Can I ask what to look for, gasses blowing?
Post #101794 22nd Nov 2011 11:04pm
Signs of soot is the main visual.
Post #101833 23rd Nov 2011 9:50am
The first sign is usually a squeaking or whistling noise, which is the gases escaping under pressure. Darren
Post #101851 23rd Nov 2011 10:50am
