Home > Technical > Side lights coming on brake depressed |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1188 |
check the earth wire.
7th Nov 2023 11:50am |
Gal Dove Member Since: 22 Jan 2022 Location: South Wales Posts: 74 |
Thanks. Can you point me at that?
7th Nov 2023 11:55am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6633 |
I think you've probably found the problem in the NS stop/tail bulb holder.
Likely this is shorting between brake and side. Part number to replace this is XBP100190. Also change the bulb in this side anyway, it may be faulty and the cause of the overheat. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
7th Nov 2023 12:36pm |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 489 |
Incorrect bulb or bulb not fitted correctlt shorting the stop and tail contacts togeather.
7th Nov 2023 12:48pm |
Thanks to all for your help and advice - it looks like the issue might have been caused by one of the two stop and tail bulbs. I changed both of them for new ones and the issue seems to have been resolved. It's early days but fingers crossed!
Thanks again - I'll update this if there are any further issues. |
8th Nov 2023 8:27pm |
