![]() | Home > General & Technical (L663) > Off-Road Capability |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1426 ![]() ![]() ![]() |
I was in Wales earlier in the year, some great lanes and never had a problem with all the lanes we tackled, this should be a video of the Bomb Hole on Strata Florida
https://www.instagram.com/reel/Cn0FhZUAZJY/ I did have a to recover a D3 that followed me through when he got his swing away wheel carrier hooked on a rock in the bottom ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 863 ![]() ![]() ![]() |
They look so at home off road. 2008 2.4 110 Utility Station Wagon XS.
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 507 ![]() |
I did a full day at the scottish experience centre - stunning location, and what an estate to get to play around on.
Some of the trails this thing was scrambling up were incomprehensible. Basically 30 degree loose boulder fields.. truly impressive. |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
Ive done some light greenlaning, scratched a wheel but yes they are great nothing has yet bothered it on road tyres Mike
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3689 ![]() ![]() ![]() |
I’ve got mine stuck a few times!! On a grassy, wet, rutted muddy incline, it’s exactly the same place my old 90 would get stuck as well. That was a manual with ATB diffs, so I’m quite impressed that the new one is the equal of it.
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3425 ![]() ![]() |
I went to the Destination Defender event a few months back and done it in the 90 on coils. No fancy off road packs only the ediff. Phenomenal car, even on the coils it went where the air suspension cars went though needed more driver involvement.
It was actually Autocars long term loan car. ![]() Click image to enlarge 24MY 90 D250 HSE, Tasman Blue |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 788 ![]() ![]() |
Glad you enjoyed it ![]() Although technically it is all on roading being as they are part of the Kings Highway. Nothing green lane should phase a Defender though. Many lanes can be driven in a car if you know what you are doing. And certainly passable in any standard 4x4. Only thing really to watch is the size of the current model. Some of the lanes can get pretty narrow, tight and scratchy. As for overall off rod capability. The platform is very capable and has good approach and departure angles. But does rely heavily on its traction systems to make progress. I’d image should you ever get an error where the tcs no longer functioned, it would make hard work of many simple obstacles. Thankfully such errors seem to have been exceedingly rare since the Terrain Response System introduction with the D3. |
khamuul Member Since: 14 Oct 2017 Location: Teutoburg Forest Posts: 24 ![]() ![]() ![]() |
![]() Click image to enlarge ![]() |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1432 ![]() ![]() |
![]() It's still an impressive and capable wagon though. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2921 ![]() ![]() |
l've found my base specification Defender 90 is very impressive off road.
The main issue l have is the width of the vehicle. l struggle to get to some of my customers on farms where my old Defender had no issues. lt also seems to struggle a bit in mud, most likely because of the weight. Our Jimny is best for that as it is so light it doesn't sink as much. |
RDR Member Since: 27 Apr 2018 Location: Derbyshire Posts: 595 ![]() ![]() |
Got my 2 week old Defender bogged down to the sills in a muddy field the other day pulling a water bowser. My property and something I have done many times, when I got the D5 stuck in a similar way it took a tractor to free it. 5 minutes of playing around in the Defender and it got itself out. 110 MY23.5 X Dynamic HSE
RR MY23 HSE PHEV D5 MY19 HSE - Now Sold D4 MY16 HSE Luxury - Now Sold D4 MY12 HSE - Gone D3 MY06 S - Gone but not forgotten |
Different tyres on the D5? As the traction control is the same on the Defender as it the suspension. Only the bodywork is slightly different with the D5 have worse approach/departure angles.
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
While the TR programs are very clever the car is still jolly good if you just leave it in comfort mode, select low range, use command shift sequential gear changes and used HDC if necessary. It will work fine offroad without needing TR on the Pivi Pro screen if that has failed for some strange reason. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! Last edited by Tim in Scotland on 8th Nov 2023 2:16pm. Edited 1 time in total |
Both All Terrain
I would argue the chassis set-up and suspension on the Defender have the edge on the D5 for off-road. Software is the same but it was able to raise its self much better. I also noted the RR gets itself across slippery fields much better than the D5 did and that's a much heavier PHEV. 110 MY23.5 X Dynamic HSE RR MY23 HSE PHEV D5 MY19 HSE - Now Sold D4 MY16 HSE Luxury - Now Sold D4 MY12 HSE - Gone D3 MY06 S - Gone but not forgotten |
