Home > General & Technical (L663) > CB Radio Aerial Mount
Page 3 of 3 <123
Chicken Drumstick
Tim in Scotland wrote:
Some of the South African and Aussie members have mounted the antenna on a folding mount on the trailing edge of the bonnet leading the cable through one of the factory grommeted holes in the firewall back to the cabin.
Don't think that would be a very idea for a CB arial, more likely to whip back and damage the windscreen or paint on the roof.
Post #1014042 5th Nov 2023 8:52pm
zilch
Australia
The bonnet mount is from Tuff Ant, I also have this fitted and can swap out 2.1 and 6.6 antennas
without the fear of it “whipping” back and damaging anything , you can even fully open the bonnet and
the antenna sits above the screen with plenty of clearance
 yet another pommie bar steward down under
MY20 110 P400 SE Defender
MY10 3.0 RR Sport
Post #1014059 6th Nov 2023 7:34am
Chicken Drumstick
In the UK we are mostly limited to CB radios which means the antenna are usually long and bendy. As long rigid ones would be prone to damage.
Something like this:
They move about a lot, esp if you catch low hanging branches and the like.
In other parts of the world you can use radios with different frequencies and allow for more compact antennas.
The only other option in the UK would be a PMR446 radio which is a UHF frequency and would allow for a smaller more compact antenna. But legally PMR446's sets aren't suppose to have a detachable antenna. And while there are a few car based sets, it makes wiring them in harder as the antenna is fixed to the wiring. You would also need to get everyone in your group to switch to PMR446 too and CB is still more common.
For anything else you'd need a HAM radio licence. But again you'd need to get everyone in your group to pay, take and pass the HAM radio test.
Post #1014064 6th Nov 2023 9:46am
PaulM78
England 2016 Defender 110 Other CSW Auto Tamar Blue
Expensive is that bracket!
I’d worry about the antenna slapping the back of the door as well, most have a loading coil at the bottom
Post #1014101 6th Nov 2023 1:09pm
zilch
Australia
Thumbs Up Strewth I forgot the UK is still a bit 🚫 when it comes to transmission gear.. yet another pommie bar steward down under
MY10 3.0 RR Sport
Post #1014179 7th Nov 2023 6:28am
PaulM78
Thought that would be the easy route out.
Any idea on how much the brackets are?
Post #1018654 18th Dec 2023 11:28am
PaulM78
RLD wrote:
yes they fit as long as you tighten them up properly
I’d like two brackets, tried a PM, anyone know if Ray / RLD is still doing these please?
Post #1019886 2nd Jan 2024 6:37pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
I've dropped you a PM Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1019910 2nd Jan 2024 10:41pm
RadioDiscovery
Australia
Aerial Mount
Hi - I have seen reference and pictures of "Ray's Mount" that goes on the roof rails of a Defender. Please will someone let me know where I can get this mount. Just taken delivery of my new Defender and looking for aerial mounting options and the pictures of the mount look like what I am after.
Post #1047682 4th Oct 2024 3:28pm
Hairy Dan
This is Ray's profile https://www.defender2.net/forum/member-rld.html
You will need 3 posts to to be able to PM him so how's the weather in Sydney? Whistle Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1047683 4th Oct 2024 3:59pm
RadioDiscovery
Australia
Many thanks to "Hairy Dan" for a very prompt response.
Post #1047710 5th Oct 2024 5:58am
RadioDiscovery
Australia
I have ordered a couple of bonnet mounts similar to the posting from "zilch". I need to mount multiple aerials for VHF/UHF (and occasionally HF). The magmounts that worked fine on my Discovery 1, Discovery 2 and Discovery 4 are now of no use except maybe on my wife's car Big Cry .
Post #1047711 5th Oct 2024 6:04am
Hairy Dan
Check your PM's Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #1047755 5th Oct 2024 2:29pm
zilch
Australia
The tuff ant mount is an easy fit and uses the existing hinge bolts, you can route the coax under the
plastic trim and enter the cabin via the steering column rubber grommet in the firewall.. Minimal fuss.
I have fitted a GME XRS 370 under the centre console storage area and used a holdmyphones mount for the XRS Mic, attached the mic mount to the dash mount with double sided tape, no drilling, just a small hole needed in in the steering column grommet to feed the coax.. simples. yet another pommie bar steward down under
MY10 3.0 RR Sport
Post #1047826 6th Oct 2024 1:57am
RadioDiscovery
Australia
I have just received the first of my bonnet mounts from GMF (www.GMF4x4.au) who are located in Bathurst NSW.
Post #1048085 9th Oct 2024 12:08am
Page 3 of 3 <123
