![]() | Home > General & Technical (L663) > Has it begun? |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
Prepared to be ......... disappointed !!!
Mark my words. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3016 ![]() ![]() |
Had no issues with mine.
Spares supply has improved so you may be okay. At least you got a courtesy vehicle straight away, l had to wait two months for the hose recall because l needed a courtesy vehicle. Yours won't need the hose recall, that was on the 2022 |
Guyneutron Member Since: 09 Feb 2023 Location: London Posts: 18 ![]() ![]() |
Update!
Faulty BISG, and guess what…. Part on back order! Hahahahha |
DFNDER Member Since: 02 Oct 2023 Location: Perth WA Posts: 140 ![]() ![]() |
What's BSIG?
It stands for belt-integrated starter-generator, which is a device at the heart of mild-hybrid systems, which in turn are synonymous with modern 48V electrical systems.
In short, and alternator substitute rated at 48v instead of 12V . |
l bet one of those isn't cheap if it fails outside the warranty
Retiredone Member Since: 05 Nov 2023 Location: Santa Fe Posts: 2 ![]() ![]() |
Audi has been experiencing failure of their belt starter generator (BSG) in vehicles equipped with their 48V mild hybrid system. No warning before failure, just red lights and it’s done. Affects the A6, A8, Q7, Q8, RSQ8.
I just sold my Q8. Mine hadn’t failed yet but at least one person on the Q8 forum experienced a second failure after replacement. Audi extended the warrant to 7 years unlimited miles but still has no fix. I didn’t take it on long trips to avoid being stranded. Replaced it with a 2024 Defender 110 SE with the P500 V8. No 48V system. Hope this is a one off failure for Defenders. Mercedes uses a similar system with an ISG, I haven’t heard of issues with their system. When the first Audi failures started, back orders where 3-4 moths, now 2-3 weeks. |
Here’s the link to the Q8 forum on the BSG failures
https://www.audiworld.com/forums/audi-q8-2...n-2969046/ |
Currently im waiting for this to be back i. Stock Nov 24th…. Not impressed but
![]() The Land Rover guy who came out to have a look, plugged his computer in, and said fault was first flagged october 2nd, i bought car October 20th, i wanna know how come they didnt see it when they do the “160 point check” (i bought car with 3600 miles on it) |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1468 ![]() ![]() |
Reject it and swap it for a proper 6 or 8 cylinder motor
Nashvegas Member Since: 25 Dec 2021 Location: Portland, Oregon Posts: 40 ![]() ![]() |
MSRP $2010 USD over here in the USA. Which is alot for an alternator ! |
