Home > Puma (Tdci) > Retrieve object from cylinder!!!
Page 1 of 3 123>
SilverPuma
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Hi all. Today I had that feeling of dread when changing the injectors on the 2.4 TDCI. All went well until having taken the injectors out I placed the metal blanking plugs in the bottom of the injector hole. These are put in to stop carbon and crud dropping into the cylinder whilst cleaning the injector hole.
They look similar to a rivnut with the flange stopping it dropping through the small hole, only on one the flange was too small and it actually dropped into the cylinder itself. My immediate thought is I’m stuffed and will have to get the head taken off but thought I’d check with you guys in case you’ve successfully got something metallic out of the cylinder using any other method?
Post #1012906 27th Oct 2023 7:56pm
Chugga90
Hose adapted to suit vacuum/suction device?
Bore scope and a suitable magnetic probe/retrieval item?
Post #1012909 27th Oct 2023 8:16pm
SilverPuma
Unfortunately it is just slight smaller than the hole and would literally have to come out stood upright. The injector hole isn’t really and option, I wondering about extraction via exhaust or inlet valve but not sure how far they open etc…?
Post #1012910 27th Oct 2023 8:22pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I've never tried it, but a vacuum seems a good idea to me, perhaps with a small tube attached with tape. I can't imagine you'll get much joy through the valves. Good luck!
Post #1012918 27th Oct 2023 9:12pm
peanutbob
I wonder if a mini vacuum like this or similar might work?
https://www.amazon.co.uk/Reesibi-Brushless...&psc=1
Post #1012923 27th Oct 2023 10:40pm
If it's gone right in it will be a head off job, I'm afraid. There is no chance of getting it out the way it went in.
Post #1012925 27th Oct 2023 10:50pm
landhank
Germany
If it's a 2.4l engine it's an easy job to remove the intake manifold. Maybe you have the chance to get it out via an open intake valve with a small magnet on a thin wire?!
Post #1012932 28th Oct 2023 6:35am
Clemmo
England 2010 Defender 90 Puma 2.4 HT Stornoway Grey
You can invest much time and thought into how.... Big Cry
the only sure way is Head Off.
Not the most difficult job. Just many items to remove /disconnect.
Fit a quality gasket set and you are assured all will be ok.
Follow technical data for tightening down..( and new bolts x18 required as stretch type)
Clemmo Thumbs Up Make today a little better than yesterday but not so good as tomorrow....
Defender 90 HT............Pangea Green
BMW X3 Msport............Carbon Black
Mini Electric................Grey. (wow!)
MGB Roadster……..........Vermillion 17k miles
Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun
Post #1012941 28th Oct 2023 8:04am
SilverPuma
Thanks for the replies guys.
As I need to take the inlet manifold off to remove the head anyway I may as well at that stage see if I can get it out with a wire and magnet.
Does anyone know how far the valve opens i.e. what clearance it gives? If they only open 5mm for example I know that won’t be enough to get the item out in any case. 10mm opening would though.
Has anyone taken the head off? If so, how long would this be likely to take if nothing goes wrong.
Thanks again
Post #1012951 28th Oct 2023 9:24am
Clemmo
If you have all the parts/tools you need its a DIY job easily in a day.
Likelihood is you will find something breaks or needs replacing.
Clemmo Make today a little better than yesterday but not so good as tomorrow....
Post #1012953 28th Oct 2023 9:48am
Clemmo
Quality parts
https://www.turnerengineering.co.uk/lr0370...2x20635021
Post #1012955 28th Oct 2023 9:52am
SilverPuma
Hopefully my existing head should be fine. If I take the head off and obviously replace the injectors, and code them, is there anything else worth doing while I’m at it? (Timing chain etc)
The Defender had no other issues except the injector blow by / seals and is ok 85K.
Thanks
Post #1012957 28th Oct 2023 10:08am
I'd certainly inspect the timing chain etc for wear and consider replacing it. The timing cover's not reusable so will need replacing along with the crankshaft front seal. I'd check the heater plugs because access is much better with the engine partly dismantled. I'd also check the condition of the exhaust manifold stud holes in the head since the threads are prone to stripping and it's easier to helicoil them off the engine.
It's also worth checking the engine harness for chafing (another well-known problem and fire risk) while it's freed from its securing points, and also worth checking the none of the cams have slipped on the camshafts.
Apart from all that, just check for wear and tear which should be minimal on such a low mileage engine.
Post #1012960 28th Oct 2023 11:43am
SilverPuma
Does anyone know the valve lift? If it’s greater than 8mm then I may have a chance with wire and magnet / compressed air through injector hole to push it out past valve (slim chance I know…)
Exhaust and inlet valve lift would be brilliant as I cannot find this info from my searches. Again much appreciated guys
Post #1012966 28th Oct 2023 12:26pm
Tommybahama32
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
I had a Citroen 1.6 HDI engine that the glow plug tip dropped into the cylinder, I was about to take off the head, I did a search on line and some body said they had the same issue. They removed the injector and used a flexible magnet and managed to remove it. So I thought id give it a try. It worked, the magnet just fits through the hole that the nozzle pokes through. I put the magnet into the cylinder used an air line to move the broken bit. I kept thinking to myself this will never work and the head will have to come off. After many attempts and still to this day I don't know how I did it but out it came. The broken bit was barely magnetic and it had to come out vertically I still have the broken bit taped to the lid of my toolbox. Might be worth a try. Saved me a awful lot of extra work. Thumbs Up
Post #1012969 28th Oct 2023 1:38pm
Page 1 of 3 123>
