Home > General & Technical (L663) > Configurable TR
DefenderMidlands
Configurable TR
CONFIGURABLE TERRAIN RESPONSE. This shows the icon from the rotary knob but I cannot actually scroll across to it and select it, anyone else had this? Only via touchscreen
Configurable TR
MultiCAN-736 Config TR Fitment - Not Configured > change to Off Road Configuration
MultiCAN-755 Config TR Mode - Not available for selection > Change to Available for selection with timeout
What has anyone set these parameters at when using TR, its quite complicated to know best settings?
Post #1011740 19th Oct 2023 8:11am
DFNDER
Australia
You need to tap the icon on the Pivi screen to select.
Post #1011745 19th Oct 2023 8:34am
Defendit..
Netherlands
Just before going off-road select AUTO.
Really incredible what it can do, also on wet roads.
When situations change or coming more demanding choose the right modes or lock everything in configurable. No Mud flaps for my 90.!
P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods..
Post #1011805 19th Oct 2023 3:42pm
Hairy Dan
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Chawton White
Re: Configurable TR
There is a way to select it with the rotary knob as it does on mine although mine was enabled by Hunters Prestige. I'm not at home for the next few days so can't check my ccf file, hopefully somebody else will chime in with the setting Thumbs Up Cheers Ian
22MY Defender 110 D200 SE, Fuji White.
Kielder 4x4 Safari
Instagram @defender_v8
Post #1011810 19th Oct 2023 4:14pm
DefenderMidlands
I wonder if it’s anything to do with ‘with timeout” or without timeout’.
A few settings in the gap tool have these options but nobody seems to know what the difference is
Post #1011850 19th Oct 2023 8:01pm
Nashvegas
United States
Here's the answer - To get Dynamic mode to be selectable with rotary. It’s 777 down below
EUCD - 245 Dynamic 1 set to “Dynamic 1 Content with Configurable Dynamic Mode Screen”
MultiCAN - 562 DynamicProgMode. Set to “Available for Selection Without Timeout”
MultiCAN - 605 ConfigDynamicMode. Set to “Fitted”
MultiCAN - 682 DynamicLiteMode. Set to “Available for Selection Without Timeout”
MultiCAN - 777 Ter Dyn Select In FCPB. Set to “rotary used for selection within touch screen”
(Note I also tried 778, but it didn’t make auto selectable via rotary)
Post #1012139 22nd Oct 2023 6:33pm
DefenderMidlands
It’s configurable terrain response that can’t be selected via rotary, only via touchscreen, not dynamic mode?
Post #1012143 22nd Oct 2023 8:10pm
sullivan1337
United States
Both are indeed able to be selected from the rotary!
https://www.defender2.net/forum/post1013294.html#1013294 24MY Defender 110 P400 X-Dynamic SE, Pangea Green.
Post #1013295 31st Oct 2023 4:57am
