Home > Puma (Tdci) > Shocks
Page 1 of 9 123456789>
defender75
2009 Defender 110 Puma 2.4 XS CSW Chawton White
Shocks
I put bilsteins on my truck yesterday. After 4000 miles I had enough of the bouncing with the stock set up. I was just wondering who makes the genuine shocks. Each one is stamped Land Rover and made in Spain. Werent they woodhead in the past?
Post #100562 17th Nov 2011 5:08pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
How do you find the bilsteins ?
I have them and find them great Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #100568 17th Nov 2011 5:50pm
defender75
Over rough stuff they are much better than stock but on flat smooth roads the truck is still a bit bouncy. Did you change your springs?
Post #100664 18th Nov 2011 2:50am
fekete
Yes i put Discovery H'D springs on as well....i find the ride much better Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #100676 18th Nov 2011 8:34am
defender75
disco hd springs fit?
I guess the truck comes standard with hd springs?
Post #100837 18th Nov 2011 10:55pm
defender75
My truck is lhd and the front drivers side shock has a white stripe. Passenger side has a yellow.
Rear I don't see a stripe. Anyone have a clue what my 09 truck has. I just want a nice ride on the road. Truck is stock with a g4 rack and used on road 99.999999 percent of the time.
Post #101003 19th Nov 2011 5:28pm
wslr
You've got the standard LR front springs for the 110 LHD on the front - NRC8044 (Driver, White, Front) and the NRC8045 (Passenger, Yellow, Front).
Rear you could have the helper coil spring inserted inside the main road spring? White/Green, Brown/Purple???
Make sure your tyre pressures are OK before throwing money at a possible solution. 30/38psi works well usually.
Post #101008 19th Nov 2011 5:39pm
defender75
I don't see any helper springs inside. Running 30 in the front and 35 in the back.
265/75/16 km2s
Post #101059 19th Nov 2011 7:54pm
fishrider
United Kingdom 2011 Defender 110 Puma 2.4 XS CSW Keswick Green
I too am looking to change my springs for more compliant ones to give a better ride on the road. I swear badly maintained tarmac is worse than a good gravel dirt road. The roads are so bumpy compared with 5 years ago.
Tried looking into it but the only things that come up are performance springs for turning the Landy into a performance racer or HD springs for over landing under a full load.
Would be great to hear about ones that are rated for carrying passengers only. Mines a stock 110 SW 2010 110 HT TD5 - 110 XS SW Puma
Post #101097 19th Nov 2011 10:38pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
my came with HD springs on the rear and had a very hard bouncy ride, don't often carry any real weight or tow so i changed them for standard LR road springs and put on qood quality shocks all round. made a huge difference. BM52
Post #101098 19th Nov 2011 10:54pm
defender75
YOu didn't change the front springs? Just the back? Didn't the truck sag?
My truck si a 110 sw if that matters.
Post #101100 19th Nov 2011 11:15pm
bm52
just the rear, all level and fine - no issues just a smoother ride. BM52
Post #101101 19th Nov 2011 11:20pm
fishrider
I'm surprised the 90 comes with HD springs . Is that anything to do with it being XS spec ?
Mines 110 XS SW haven't checked but assumed it was on standard springs 110 HT TD5 - 110 XS SW Puma
Post #101102 19th Nov 2011 11:31pm
wslr
If you are considering the change, you could do a lot worse than a Terrafirma kit.
You have to option of light/medium/heavy springs and can either use the gas dampers, or the big bore oil filled units. They are good value and high quality, and you can mix them, so light front and medium rear.
Post #101103 19th Nov 2011 11:45pm
BigMike
Terrafirma kit is poor quality (in my opinion). I sent shocks back to them after bushes went in less than 2000 miles. shocks were so hard there is no way the bushes could have survived.
The very best set up I've ever had was OME shocks and Iron Man "B" springs. magic on the road, fabulous offroad. If I was having another 90 I'd go all Iron Man.
Post #101104 19th Nov 2011 11:59pm
