![]() | Home > Technical > how does the hand brake work |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello blackwolf
Thanks and good to know, I have applied and reapplied the Handbrake now several times, and what I've ended up with appears to be a marginal alteration. The rear prop shaft is 'braked' at two clicks but with minimal force, a car ramp for example, 3 clicks are need to hold the vehicle. A 5 mile (unknown to me) road test shows none of the symptoms you list, maybe I've been lucky as you say, but I suspect that I've not changed things enough. I'm interested in your comment... ".... adjustments for wear must be made with the backplate adjuster." Does this mean periodically tighten to 25NM, back off 1 1/2 turns, then get 'the clicks right' at the 'double nut adjuster', as I have done... ![]() Thanks again SKIP https://www.defender2.net/forum/topic83242.html |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17704 ![]() ![]() ![]() |
Yes, that is right, however it doesn't need doing often since under normal circumstances the handbrake is never applied when moving so experiences negligible wear (it will only wear out if it fills with mud, or is adjusted so tight that it drags). Also once you have "got the clicks right" you shouldn't need to adjust the cable again unless it stretches - if the shoes wear there will be more clicks, but then adjusting the shoes will reduce the number of clicks again.
The Puma is also fairly legendary for leaking oil into the drum, which results in extreme force being needed on the HB lever and even then the brake may not hold. Very different symptoms to just being out of adjustment. |
Thanks blackwolf
That all makes sense... (and well explained)... ![]() https://www.defender2.net/forum/topic83242.html |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3529 ![]() ![]() ![]() |
On my early 90, there is an oil catch plate that directs any oil leak away from the shoes and drums, and let the oil drip on the external side of the back plate. Refer to item 16
https://www.lrworkshop.com/diagrams/land-r...d_53765#16 I cannot recall seeing anything that could do a similar function when I removed the transfer case from my Puma. Granted, the shoes orientation rotated by 90 degree, but oil would still drip on the working surface of the drum. https://www.lrworkshop.com/diagrams/land-r...able_45158 Indeed the Puma engine / gearboxes installation is a nose up. So was the location of the fill plug position changed on a Puma transfer case? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
That's because there isn't any such thing on the Puma.
Yes, exactly.
You have to ask? ![]() Land-Rover has much to be ashamed of since 2007. ![]() |
