![]() | Home > Technical > Help Identifying a noise please? |
sasdiscos Member Since: 22 Jul 2023 Location: UK Posts: 155 ![]() ![]() |
You can hear it from 2nd gear onwards, this leads me to think gearbox?
Thoughts? Really don't need this after all the work ive put in!!! Thanks, Steve. |
So, after a bit of research it sounds like its actually the engine pinking.
This issue I have is setting the timing perfectly I think, the engine has to mark for tdc. I will remove spark plug 1 and get as best I can using this method. Steve |
