Home > My Defender > New member with UK NAS AND 50TH Development Car
Page 8 of 11 <123 ... 78 91011>
sasdiscos
No exhaust yet. First start since rebuild and I’m just testing it.
Should have it roadworthy in the next few weeks I’m hoping before the weather turns.
Steve.
Post #1007550 14th Sep 2023 4:19am
Martin
Site Admin
Re: She’s back from the dead…..again! Drinking petrol on
sasdiscos wrote:
Thanks to all the help from you guys. Martin. It was neutral 27 that was the issue. Put that down and away she went.
Glad to help Whistle  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1007598 14th Sep 2023 1:29pm
L110CDL
That sounds great, thanks for the video Cool Clayton.
Keeper.
Post #1007626 14th Sep 2023 7:28pm
mini Anaconda
Good work. Sounds great without the exhaust Mr. Green BORG - Bucks & Oxon 4x4 Response Group
Post #1007721 15th Sep 2023 2:12pm
sasdiscos
Right then.
Been playing with it all day.
Set TPS to within limits.
Set MAF to 1.8v at no load.
Set dist.
Set throttle butterfly 1mm open.
No air leaks all pipes connected.
It ran once this morn but then it’s still over fuelling.
Wouldn’t start again. Have checked spark at all plugs. Ok.
Marked timing and set. Advanced by 8 deg. Nothing. Tries to fire occasionally but think it’s flooding. Rovergauge is not giving me a maf reading.
Have not been able to start again all day.
What am I missing?
Post #1007857 16th Sep 2023 3:45pm
sasdiscos
‘‘Twas flooded.
Got her running well today. Even good enough to run up and down the road.
I’m struggling to get the timing just right.
And when I get close it’s all good and then get a misfire.
I think I will have to check the injectors again.
But it’s progress that’s for sure.
Post #1007926 17th Sep 2023 11:20am
sasdiscos
With the v8 injectors. Does anyone know if they have to have the filters fitted? Does this affect the spray pattern? Mine have nothing fitted.
Steve.
Post #1007980 17th Sep 2023 5:19pm
sasdiscos
Full set of new injectors. Now all back together.
Took her out today and gave her a good run.
Still idling slightly high and have an air leak I can’t find but it’s running really well. Pulls well and sounds nice.
?si=7FSMlcPXqy8f9KbN
Next job is to lower it and get it re sprayed. Maybe next spring now.
Steve.
Post #1009404 29th Sep 2023 5:53pm
Chugga90
Many years ago I had a 90 with engine and box out of a classic Range Rover. That had idling issues at one point.
There is a stepper motor, I think it was called. In the inlet between the air filter and plenum chamber somewhere.
Cannot recall what or how it was fixed?
Post #1009418 29th Sep 2023 7:04pm
L110CDL
Many thanks for the video and that V8 burble sounds well good Cool Clayton.
Keeper.
Post #1009421 29th Sep 2023 7:17pm
sasdiscos
Can anyone tell me the part number for the rad. Have a leak on that now but only when it’s cold.
Thanks.
Post #1009458 30th Sep 2023 6:48am
If you're looking for information about parts for this vehicle then you could do a lot worse than contact Philip Bashall of the Dunsfold Collection. Apart from the fact that he's probably forgotten more about special Land Rovers than most of us will ever know, he's actually got a NAS prototype in the collection:
https://www.dunsfoldcollection.co.uk/colle...-vehicle#v Darren
Post #1009642 1st Oct 2023 4:23pm
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
No need to use a 50th rad. I used a D Turbo rad on mine. It’s run for 4 years just fine and includes an engine oil cooler/warmer element if you have the pipework. Part no. NTC6168.
You’ll just need a T piece for the header tank vent.
 JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #1009696 2nd Oct 2023 7:10am
sasdiscos
Excellent.
Good news is I think it was just the hose. It was dripping and the wind was blowing it up into the fins.
Thanks for the reply.
Steve.
Post #1009698 2nd Oct 2023 7:55am
NickMc
Other option is to get it re-cored at a radiator place.
Post #1009709 2nd Oct 2023 9:54am
