Home > My Defender > New member with UK NAS AND 50TH Development Car
Page 2 of 11 <123 ... 91011>
Very cool!! Cool
Post #1001331 22nd Jul 2023 8:35pm
JeremyJ
Very interesting vehicle I’ve been keeping an eye on.
Couple of thoughts - there are far better places than RPI…
I believe it’s a ‘95 model year development vehicle initially. I don’t think it was a 50th development vehicle but could be wrong. Greg King would be a good starting point - most active (I think) on some of the Facebook groups - if you’re not on it drop me a message and I’ll ask him if he knows it’s history etc.
Personally I think it would be a shame to make it a 50th replica - this would be far more interesting as a the development vehicle it was than something it wasn’t.
Either way, great vehicle - enjoy it and good luck with it!
Post #1001364 23rd Jul 2023 8:36am
Lodelaner
United Kingdom 1988 Defender 90 V8 Petrol ST Shire Blue
sasdiscos wrote:
Hi yes, want to put back to original, get rid of the lift etc.
Found massive holes in the exhaust.
Need to fit a new one but don't know if I should fit cats or not.
It does have euro 2 emissions on the log book so guessing ill need them, but don't know what to get.
Its got through emissions ok with what it has now, similar to the one pictured, but its on lpg, so assume the emissions will go up when I put it back onto petrol.
Hi Steve - I've had a couple of 50ths, a couple of V8s and converted a diesel V8 and as a result have swallowed the parts book!
https://new.lrcat.com is your route to find parts - and cross reference to what other Land Rover cars the parts were fitted to.
https://www.lrworkshop.com helps you find and price the parts you need.
The good news is that the exhaust downpipe routing is the same for all the 3.9 V8s (the Range Rover Classic, Discovery 1 V8 and NAS Defender) to the centre silencer box. From the centre silencer box aft you can fit a TD5 tailpipe - the bore is correct and it was the part that LR superseded the original for the 50th. I've got a Genuine new old stock NAS V8 centre exhaust box in my garage part no. ESR2687 if that helps you can have for £100. Unobtainium now.
First you need to know what the engine. Do you know if that's the one that was in there and fitted by Land Rover originally? If so it would be good to keep it and I'm hoping it's a Serpentine belted 3.9. Can you post a photo/ photos of the front end of the engine, exhaust manifolds so we can advise best rote to take? Do you know if it's the original engine? If so it might be worth keeping and restoring the fuelling to it.
However - If you want it to be faithful to a 50th/NAS auto you'll need a 4 litre GEMs engine. You say your engine has a dizzy - which means that you can't convert it to GEMS ECU (which is distributorless, uses coilpacks using a crank position sensor and has a shorter cam than the engine you have fitted).
Your solution would be to take a GEMS V8 from a scrapped Range Rover p38 and get the Tornado standalone ECU to make it work. If you go this route you'll need to fit catalytic converters and plug in the 4x Lambda sensors etc. Although it's a good solution, personally I wouldn't entertain this approach based on cost alone.
But, I would suggest that if you're not wedded to GEMS you go down the 3.9 14CUX Lucas route - its much simpler.
If you don't want CATs you can fit an older engine as long as its age is properly documented and its number is on the V5C.
See the MOT manual here - https://www.gov.uk/guidance/mot-inspection...on-8-2-1-2
Scroll down to the heading Vehicles fitted with a different engine
If a vehicle first used before 1 September 2002 is fitted with an engine that’s older than the vehicle, you must test it to the standards applicable for the engine. The vehicle presenter must have proof of the age of the engine.
If a vehicle first used on or after 1 September 2002 is fitted with a different engine, you must test it to the emissions standards for the age of the vehicle.
 JB
@Lodelaner Instagram
Youtube greenlaning and other LR related content
Post #1001400 23rd Jul 2023 12:29pm
Lodelaner
sasdiscos wrote:
I think a td5 tank will do the job as they are supposed to be the same. Im reluctant to give him 500 quid and drive all the way to b, ham again.
The tanks mount in different ways and aren't directly interchangeable. IIRC the 50th NAS relies on a skid plate/ cradle and the td5 tank uses supporting straps and cradle. The details are a bit hazy in my mind, but maybe you'll need to buy some td5 tank retrofit mounts, and the anti-roll bar mounts are further inboard on the 50th - mounting through the skid plate rather than to the cradle ends.
The Fuel pump is another thing - you'll need a high pressure petrol one and you'll need to check the both the height from pick-up to collar - and check that the collar fits to the td5 tank. Chances are there's an alternative - but to my mind I might be tempted to just negotiate with the man and save a whole load of pain.
Romadog on here may be your man, I bought one of my 50ths off him and he's built/building one from scratch. JB
Post #1001407 23rd Jul 2023 1:52pm
sasdiscos
Wow, thanks loadlaner. Loads to absorb there.
Think I’ve got a bigger project than I first thought tbh.
I spent the morning removing the spit exhausts. All studs came out but 1 which snapped!
Spent the rest of the day removing the wing so I can get access to drill it out and re tap.
Post #1001424 23rd Jul 2023 4:35pm
Lodelaner
That looks like a GEMs engine! Not sure where the dizzy would go… JB
Post #1001425 23rd Jul 2023 4:41pm
sasdiscos
I believe it is a gems engine with a new front case for a dizzy.
Will the exhaust I’m looking at fit?
It looks like what is on there now.
I need to get it running again. Get it filled with gas and get it mot’d.
It’s been passing with no cats on gas so I want to try and get 12 months on it so it buys me time.
Then up to rpi so they can fit the ecu for me.
Does any one have any tips for getting the stud out? I was going to start with a 4mm drill and work up slowly, then try and either reverse tap it out or re tap the block. Risky business what ever I do.
Steve.
Post #1001427 23rd Jul 2023 4:50pm
sasdiscos
Post #1001428 23rd Jul 2023 4:55pm
mini Anaconda
Unfortunately I can't be any help technically but looks like a great vehicle with history. Good luck. Thumbs Up BORG - Bucks & Oxon 4x4 Response Group
Post #1001430 23rd Jul 2023 4:59pm
Lodelaner
It will fit, but that exhaust with its 4 branch headers isn’t right for the car and doesn’t have cats, so you’ll fail the MOT on petrol.
Ive been in V8s with similar SS exhausts, they’re more resonant and without tail silencer drones. Add auto and the drone sounds like a demented mooing cow.
To do it properly…
Manifolds are RRC/Disco 1 V8.
https://www.ebay.co.uk/itm/304867077734
Cats and down pipes (with Lambda sensor holes.)
https://rimmerbros.com/Item--i-ESR3063P
Then you can fit Puma/TD5 90 centre box and tailpipe in mild steel. https://rimmerbros.com/Item--i-LR1127MSP JB
Post #1001447 23rd Jul 2023 7:03pm
sasdiscos
Thank you JB
Also, are the threads 5/16 unf? Need to buy a tap.
Steve
Post #1001448 23rd Jul 2023 7:15pm
Lodelaner
Welcome Steve. Looks like a bit of a puzzle of a car but very interesting.
Exhaust manifold to head bolts are 3/8 UNC - coarse thread. JB
Post #1001452 23rd Jul 2023 7:31pm
sasdiscos
Actually looks like they are m10 in the head and unf on the other end.
Thats good as I have all the kit for that.
Just ordered the the manifolds you sent the link to and the cats.
Thanks.
Post #1001453 23rd Jul 2023 7:32pm
Be careful, an M10 x 1.5mm pitch thread is incredibly similar to a 3/8" X 16tpi UNC thread, the pitch of the latter being 1.5875mm.
It would be exceptionally unusual to have an stud as you describe.
Post #1001464 23rd Jul 2023 9:40pm
sasdiscos
The block must be unc then and the stud unf.
I may just tap the block with m10.
Steve.
Post #1001517 24th Jul 2023 10:57am
