![]() | Home > Modifications & Maintenance (L663) > Mirror Clearsight retrofit |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1431 ![]() ![]() ![]() |
From my post on page 2
These are the part numbers for a UK model without the garage opener. ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
bucks405 Member Since: 26 Sep 2023 Location: Calgary Posts: 4 ![]() ![]() |
Hi all , I finally did my clearsight retrofit with my son for my 130 and it works perfectly. The hardest part is to fish the cable from the back to the first light cause need to pass thru the seat belt buckle at the back, I bet only 130 has this challenge cause is a seven seaters.
A big thank for to all of you for providing all the useful information in this forum. My next project will be adding the PLUMB side steps , PLUMB spare tire case , PLUMB back extension boxes , tail gate soft close , and the extra brake lights and the headlights . Maybe also add the lock furl door flap as well. Hope could find more topic for the above |
G4R1 Member Since: 17 Aug 2020 Location: Barnet/Limassol Posts: 131 ![]() ![]() |
Thank you guys for sharing!
I just completed the upgrade, I don't have the sunroof so it took me under an hour with installation and activation. Total cost £570 3.0L MHVE D200 S Pangea Green+Black Pack Adv. + Off-Road and Family Packs |
DefenderMidlands Member Since: 08 Mar 2023 Location: West Midlands Posts: 250 ![]() ![]() |
Well done. I couldn’t find the parts anywhere at a reasonable price in the uk MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1457 ![]() ![]() |
Good effort. ![]() You're not secretly Lawrance Stroll? ![]() ![]() Look forward to seeing you all 'Plumbed in'. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
They do come up on Ebay from time to time you just have to be quick ![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
inith5 Member Since: 08 Apr 2023 Location: Bavaria Posts: 30 ![]() ![]() |
Hello, also interested in retrofitting this. Just a few questions about wiring. Is it correct that the Fakra cable has to be 3m long? and you connect it directly from the antenna connection directly to the mirror? how do you connect the LR repair cable? Sorry for the questions, the solution is probably already in the thread but I can't figure it out. 23.5MY Defender 110 D250 HSE
The reason why you need the LR repair cable is the Fakra cable comes as "Male" on one end and "Female" on the other. But to connect the mirror to the camera you need "Female" connectors on both ends.
Connecting the LR repair cable to the Fakra cable will provide you with a cable with "Female" connectors on both ends. 3.0L MHVE D200 S Pangea Green+Black Pack Adv. + Off-Road and Family Packs |
Hello everyone, I also retrofitted the camera and the mirror with a garage door opener. What surprised me was the fact that after everything was laid and connected, the mirror already worked even though I hadn't changed anything with the GAP tool. But I still have the MultiCAN-711 interior mirror variant
"IRVM and Homelink" changed to "SVRM and Homelink". Many thanks to everyone who showed us how to do it and also posted lots of useful tips in words and pictures. 23.5MY Defender 110 D250 HSE |
mmbanf Member Since: 16 Mar 2021 Location: Milano Posts: 174 ![]() ![]() |
congratulations for the work,
![]() Even for me without coding I had the mirror working, but the gap found DTC errors in the memory. Marco |
Well done. I’ve never managed to find a mirror! MY23 D250 Defender 110 X-Dynamic SE, Carpathian Grey, 7 Seat, Electric Towbar
Jnhconsulting93 Member Since: 01 Mar 2024 Location: Drancy Posts: 3 ![]() ![]() |
Hello Everyone
After installing the clearsight retrofit and following the tutorials from marco and all unfortunately I would like to understand the difference you had during the electrical wiring of the retrofit. Did you have the same difference as me? During the connection i.e. a 6 pin connection without clearsight and with 8 pins with clearsight. thanks for your Help. Not ClearSight (6 pins): ![]() Click image to enlarge With Clearsight (8 pins): ![]() Click image to enlarge Last edited by Jnhconsulting93 on 1st Mar 2024 9:58pm. Edited 1 time in total |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 437 ![]() ![]() |
Good first Post, welcome !
![]() ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
Thanks defendit
