Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case
Page 22 of 39 <123 ... 212223 ... 373839>
JOW240725
I've also had the letter for our 2012 110. James
Instagram @suffolk_rovers
Post #1008799 25th Sep 2023 11:14am
Ianh
Will@LRW wrote:
Based on the EU recall's production dates, and assuming it affects all variants, the VIN ranges would be these:
BA820528 - BA826097
BA400000 - BA412050
CA412051 - CA427758
DA427759 - DA440736
About 45,000 vehicles built, with at least 70% in Europe as a whole and approx 16,000 for the UK.
It's sad that it's come to this
It looks like JLR are using the vin ranges they responded to the EU with. See above from Will@LRW. Posted on page 14 of this topic. So should cover vehicles up to sept 2013.
Post #1008803 25th Sep 2023 12:07pm
JOW240725
ours is in that range. James
Post #1008804 25th Sep 2023 12:11pm
Scotm
Scotland 2012 Defender 110 Puma 2.2 SW Orkney Grey
Just received the N706 letter for my Sept 2012 110SW.
Has anyone had any NDT/Scans of the welds? Is it possible on the vehicle without removing the axel?
An engineers report on poor welds to send to LR might convince them to replace an axle?
Post #1008815 25th Sep 2023 2:47pm
spudfan
Ireland
PAYNEY1000 has been there and done that and more yet here we are. He was instrumental in getting the French authorities to push the EU to tell JLR that the axles need to be replaced but so far this has not happened. For some reason there is an upsurge in recalls for the magic brackets to be fitted. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1008816 25th Sep 2023 2:55pm
itsdashy
United Kingdom 2012 Defender 90 Puma 2.2 PU Orkney Grey
Dinnu wrote:
itsdashy wrote:
Just checked and my MAR 2012 90 has friction welded axles which is a pleasant surprise.
Indeed a pleasant surprise.
As I do not doubt your skill to differentiate between mig and friction welded axle casing flanges, I find this so strange. My August 2012 is mig welded.
Maybe someone found an axle in their gray stock, and decided to use it. Damn, they should have discovered it 4 months later Whistle
So do you also get the N706 recall? Cool
Yup got the recall looked at the axles to check. I suppose it's best to give it back to them to put on useless bracketry.
Post #1008824 25th Sep 2023 3:51pm
Harry dog
England 2012 Defender 110 Puma 2.2 USW Orkney Grey
Front Axle brackets
I presume if you didn't contact JLR to get the brackets fitted the recall notice would sit on the vehicles records and could be flagged up on an MOT test or certainly could be an issue when it came to selling the vehicle?! Mine had an oil leak from the axle weld back in 2019 and rather than argue the toss with JLR I got a 300TDi axle fitted instead.....don't think I need the brackets now but for the above reasons will probably get them fitted.
I would have joined in the fight to get JLR to sit up and do something about the axle issue but having spent a year of my life fighting them to cover the replacement cost of an engine after the known fuel pump issue. I just couldn't face it and needed the vehicle back on the road.
Post #1008832 25th Sep 2023 4:36pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Ianh wrote:
BA820528 - BA826097
BA400000 - BA412050
CA412051 - CA427758
DA427759 - DA440736
Thanks, its helpful to have the range. My VIN is in that range but I've not received a notice. I tried contacting the local dealer who just told me there is no outstanding recall on my vehicle. So now I've tried contacting LR to see if I can get a sensible answer. Can I ask if others within the VIN range are also still waiting for a notice?
Post #1008839 25th Sep 2023 5:07pm
jst
Just had the letter too for my 2010. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1008843 25th Sep 2023 5:20pm
Race.it
Spain 2010 Defender 110 Puma 2.4 SW Alaska White
Mine is a AA vin number so I guess at some stage I should fit the brackets I brought as it’s a 2010. But outside of the recall vins Searching for my first Defender...and started just as Covid hit, so talk about timing.
5 months after starting the search I found it, and here is the details
Post #1008850 25th Sep 2023 6:16pm
It is easy to tell if you have a friction-welded axle tube, the appearance is very different to a MIG weld (and is illustrated adequately earlier in the threads on the subject).
Production of friction-welded axles came to an end late in 2010 and it was not until late 2013 that the problems associated with the initial MIG welded axles were identified and resolved, so any vehicle built within this period could have a defective axle. I do not know of any way to distinguish between a MIG welded axle built during the problem period and a MIG welded axle built after the problem was corrected, and I don't believe axle numbers were recorded, so there will be an ongoing risk in the case of vehicles with non-original axles and with second-hand MIG welded axles.
As I recall the testing carried out due to Payney's altruistic insistence actually concluded that none of the LR front axles irrespective of weld type conformed to the expected strength standard for type approval, but this is arguably a red herring in terms of the weld issue. It probably does explain the not-insignificant number of incidences of split case failures on heavily-laden chassis, such as 130 cherry-pickers, which was known to be a problem long before the ends started breaking off (as was the problem with 130 chassis failing in the middle).
Post #1008856 25th Sep 2023 7:11pm
Dinnu
According to my information, it happened about a year earlier, end of 2009, early 2010.
We also do not know what changed in the welding process to improve it, or what was the cause of the poor weld in the first place. We do not know if it was wrong material, inadequate penetration, temperature/cooling issue (wrong machine parameters) etc etc. Would had been nice if we could see an 8D report of the issue. But certainly, that will never happen. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1008960 26th Sep 2023 2:05pm
Scotm
So the recall letter is subject "Safety Recall - N706 - Front Axle Case Flange Reinforcement Brackets.
Yet my understanding is they don't reinforce anything?
Post #1009018 26th Sep 2023 5:30pm
Ianh
Correct, they don’t reinforce the axle case.
It’s just another cynical and child like attempt to word this recall as if it is the solution to a highly dangerous life threatening issue when plainly it’s not.
It’s bad enough that JLR don't care whether people die or receive life changing injuries, but for the DVSA to not force them to rectify the issue is truly shocking.
Post #1009023 26th Sep 2023 5:57pm
Scotm
The other line in the letter that got me was "during ongoing quality assessment and improvements of our Defender models" aye right - why would you now start this now 8 years after production ended?
Post #1009028 26th Sep 2023 6:13pm
