Home > In Car Electronics > Defender TD5 Cruise Control Install |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6634 |
If you apply the speedo healer to the signal from the sensor, your speedo will be wrong.
You need to install the speedo healer on the signal from the speedo down to the ECU! 1988 90 Td5 NAS soft top 2015 D90 XS SW |
22nd Sep 2023 11:41am |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Interestingly (although only tried briefly so far) my cruise control seems to still work in 5th gear now the V8 ratio gear has been fitted. 02' 110 TD5 Double Cab Rebuild Thread
22nd Sep 2023 12:46pm |
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 489 |
It shoud'nt they don't usually even with just higher transfer gears
22nd Sep 2023 2:30pm |
Higher transfer gears are a much larger change in gear ratios though whereas 5th gear change is only going from 0.77:1 to 0.732:1 (5%). 02' 110 TD5 Double Cab Rebuild Thread
22nd Sep 2023 2:40pm |
Biscuits Member Since: 27 Mar 2023 Location: Kent Posts: 60 |
Would like CC, but I too have a 10p TD5. Any quick way of knowing if the ECU is MSB or NNN ? 2001 90 TD5 SW - Juice Motors Resto Mod - Epsom Green
2024 90 D300 HSE X-Dyn HT - Santorini Black |
22nd Feb 2024 2:49pm |
