Home > In Car Electronics > Defender TD5 Cruise Control Install
Page 2 of 2 <12
Martin
Site Admin
If you apply the speedo healer to the signal from the sensor, your speedo will be wrong.
You need to install the speedo healer on the signal from the speedo down to the ECU!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1008459 22nd Sep 2023 11:41am
rallysteve
Interestingly (although only tried briefly so far) my cruise control seems to still work in 5th gear now the V8 ratio gear has been fitted. 02' 110 TD5 Double Cab Rebuild Thread
Post #1008468 22nd Sep 2023 12:46pm
Linds Hanson
It shoud'nt they don't usually even with just higher transfer gears
Post #1008478 22nd Sep 2023 2:30pm
rallysteve
Higher transfer gears are a much larger change in gear ratios though whereas 5th gear change is only going from 0.77:1 to 0.732:1 (5%). 02' 110 TD5 Double Cab Rebuild Thread
Post #1008480 22nd Sep 2023 2:40pm
Sicastle71
England 1999 Defender 90 Td5 CSW Alaska White
So the plugs supplied need to be snipped off and the Speedo wire on the ecu loom needs to be cut and the Speedo healer bridges the snipped wire. Sorry may be using the wrong terminology
Post #1008546 23rd Sep 2023 7:06am
Biscuits
United Kingdom 2001 Defender 90 Td5 CSW Epsom Green
Would like CC, but I too have a 10p TD5. Any quick way of knowing if the ECU is MSB or NNN ? 2001 90 TD5 SW - Juice Motors Resto Mod - Epsom Green
2024 90 D300 HSE X-Dyn HT - Santorini Black
Post #1025605 22nd Feb 2024 2:49pm
Page 2 of 2 <12
