![]() | Home > General & Technical (L663) > Auto lights - switching off when they shouldn't? |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1468 ![]() ![]() |
Yes, I've noticed this. When it happens I just switch to dip beam.
One of my bug bears is cars with just DRLs on in low light or bad weather, which means rear lights aren't on when they really need them. I really don't think people understand DRLs or auto lighting. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
On my previous Land Rover I did connect the rear tail lamps up to the same feed as DRLs, with a relay to switch over when Dip Beam is required.
I shall do this now my vehicle is out of LR Warranty, for what that was worth ???? I also think Europe / UK should have the same law as the US, with regard to 'side markers'. Amber at the front and red to the rear, as seen in the plastic wheel arches of NAS vehicles. I had those NAS bumper lights on my Disco 300, 18yrs ago. |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1440 ![]() ![]() ![]() |
On the D4 you used to be able to change the CCF to Scandinavian (I think) which would put the front DRL's and rear tail lamps on permanently, I'll have to have a look at my IID tool and see if it can be changed
![]() -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
On the Freelander 2 you needed to drill out the blanks in the rear lamp cluster and insert a bulb holder to get rear DRLs working. These were wiring to an ignition switch live fuse circuit.
I have a spare pair of the LED rear lamps for the L663, they are more difficult as everything is enclosed and sealed. It might be easier to drill the rear DRLs in the fog lamp cluster, although these are lower level lamps than I would like. I have a spare set of those also. Time to go in the workshop and play ![]() Last edited by LR Nuts on 21st Sep 2023 3:35pm. Edited 1 time in total |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 439 ![]() ![]() |
@hairydan
If you could look at it, please. Asked this for over 2.5 years ago to have the rear tailgate lights on with DRL A bloke from Sweden replied that it was unfortunately the same there.... very strange No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
I think you may need Japan setting in the CCF ?
whiterdesign Member Since: 10 Jun 2021 Location: Preston Posts: 272 ![]() ![]() |
Or just buy a Volvo 🤣. They have both front and rears on all the time. Dont understand why all cars don't do it as a safety reason. 110 XS 250 MY 23 Gondwana Stone, Cold climate pack and towbar
yes, you are correct, I remember a friend having a Volvo 245, with DLRs ....... in the late 70's !!!
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3019 ![]() ![]() |
Yes it's strange there's no "sidelight" position without the headlights coming on.
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 295 ![]() ![]() |
Yes, my Saab 99 Turbo did as well back then, front and rear. Seemed obvious to me at the time…. |
Dicky1961 Member Since: 25 Mar 2022 Location: South Yorkshire Posts: 145 ![]() ![]() |
I took my 90 back to the dealership when I first got it and told them I don’t have sidelights as an option on my car and the technicians that looked at it said they had never seen anything like it. When they approached LR about it they said there was nothing that could be done to change it. That was the design. I tow a caravan, my old D4 used to put the sidelights on as soon as the engine was started when the van was connected. I have to drive with the headlights on with the Defender if I want the van lights on. Very frustrating
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2774 ![]() ![]() |
There IS a side light position on the stalk if you need it. Only issue is that the car will default back to auto after a while. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Yes that’s right, there is a sidelights position on the stalk, if you select sidelights and then pull away in the car, when you reach about 10pm they will go out and revert to front drl’s only. If you select sidelights whilst already driving they will stop on for a while until the car decides to revert back to drl’s only or until you stop and then pull away again then the car reverts to drl’s only. So by default there is not an option for sidelights.
I think they call sidelights “parking lights “.
